Routing Second IP Address Block from ISP
routercpu
We have two front end routers configured in HSRP.  We receive two handoffs from our ISP, one active and one standby.  One handoff connects to one router and the other handoff to the other router.  We have a /29 IP block that is used for the handoff interfaces on the routers and configured for HSRP.  The ISP assigned us a /26 IP block that they route to the HSRP virtual IP on our routers.  Our routers have a default route to the default gateway of the /29 IP block.  We have received a /24 IP block from this same ISP and they are routing that /24 IP block to the HSRP virtual IP on our routers just like the /26 IP block.  So, I want to be able to use the new /24 IP block on my firewalls for NATting just like I use the /26.  I would like to do this without assigning an IP from the /24 block to my firewall.  I have tried a couple things, including assigning an IP from the /24 block as a secondary IP on the routers, but can't get it to work.  Is this possible or what is the best way to accomplish this setup?  The router configs are attached below (actual IP addresses changed for posting).  I have also attached a basic diagram of the setup.  We are using ASR1001-X routers and ASA 5545-X firewalls.
Router 1
version 15.4
no platform punt-keepalive disable-kernel-core
hostname Router 1
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
no aaa new-model
subscriber templating
redundancy
 mode none
interface TenGigabitEthernet0/0/0
 no ip address
 shutdown
interface TenGigabitEthernet0/0/1
 no ip address
 shutdown
interface GigabitEthernet0/0/0
 description Peer 1 Handoff
 ip address 10.0.0.252 255.255.255.248
 standby delay minimum 30 reload 60
 standby version 2
 standby 0 ip 10.0.0.254
 standby 0 priority 110
 standby 0 preempt delay minimum 380
 negotiation auto
interface GigabitEthernet0/0/1
 description PM-PUB-MGMT-1-SWITCH g0/1
 ip address 200.0.0.4 255.255.255.0 secondary
 ip address 11.0.0.74 255.255.255.192
 standby version 2
 standby 1 ip 11.0.0.87
 standby 1 priority 110
 standby 1 preempt delay minimum 380
 negotiation auto
interface GigabitEthernet0/0/2
 no ip address
 shutdown
 no negotiation auto
interface GigabitEthernet0/0/3
 no ip address
 shutdown
 negotiation auto
interface GigabitEthernet0/0/4
 no ip address
 shutdown
 negotiation auto
interface GigabitEthernet0/0/5
 no ip address
 shutdown
 negotiation auto
 vrf forwarding Mgmt-intf
 no ip address
 shutdown
 negotiation auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 10.0.0.249
control-plane
Router 2
version 15.4
hostname Router 2
boot-start-marker
boot-end-marker
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
no aaa new-model
redundancy
 mode none
 no ip address
 shutdown
 no ip address
 shutdown
 ip address 10.0.0.253 255.255.255.248
 standby version 2
 standby 0 priority 105
 negotiation auto
 ip address 200.0.0.5 255.255.255.0 secondary
 ip address 11.0.0.75 255.255.255.192
 standby version 2
 standby 1 priority 105
 negotiation auto
 no ip address
 shutdown
 no negotiation auto
 no ip address
 shutdown
 negotiation auto
 no ip address
 shutdown
 negotiation auto
 no ip address
 shutdown
 negotiation auto
 no ip address
 shutdown
 negotiation auto
no ip http server
control-plane
Jon Marshall
You do not need an interface on either the routers or the firewalls with an IP from the new IP subnet.
Just add a route to each router for the new IP subnet pointing to the active firewall IP address.
Then configure your NAT statements on the firewall.
Edit - the above is a common setup.
Is there a specific reason you want to use secondary IPs ?
Jon
