Routing to a T1 through 2620 Router
bryandyal
I currently have a primary Internet circuit setup through Comcast.  Modem is connected to an ASA5515X and Internet is working fine.
We installed a T1 that terminates in the same CO as a client's Internet service so we can route certain IPs from this office to their datacenter so we're all in the same network with less hops.
2620 router is setup and configured.  I have a test route setup to my corporate website that is in a different location.  I am able to ping the Internet and this site from the router and the core switch that is handling the routing, but cannot ping or access the site from the local VLAN.  Config is faily simple for this site, so I'm not sure what's going on.
To troubleshoot, I attempted to route all traffic from the network to this T1 circuit, but that does not work.  I have another site that is setup similarly with no issues.
Any ideas?  Configs attached...if you need more, I can upload the full thing.
2 Accepted Solutions
do below configuration
interface vlan 100
ip nat inside
interface gi 0/48
ip nat outside
ip accessl-list standard 1
permit ip 192.168.16.0 0.0.0.0255
ip nat inside source list 1 interface ge 0/48 overload
it should take care of NAT issue.
int fa0/0
ip nat inside
int s0/0
ip nat outside
access-list 101 permit ip 192.168.16.0 0.0.0.255 host 3.3.3.5
ip nat inside source list 101 interface s0/0 overload
Note instead of specifying the host in the acl you can use "any" if there are more destinations.
Jon
25 Replies 25
vishal vyas
Hi Bryandyal,
Are you NATing the traffic for network 192.168.16.0?
Does the ASA has a route to reach this network?
Vishal--
I wouldn't think the ASA needs a route since traffic to 3.3.3.5 is being routing from the core switch to the T1 router (2.2.2.105).
I shouldn't have even mentioned the ASA since any traffic that needs to route to the T1 never hits it.
If possible could you please upload the full config, and please highlight the new T1 line which you have installed.
T1 is connected via 2620 FE0/0 (2.2.2.105) to 3560E "Core Switch" via Gig0/48 (2.2.2.106).  You'll see the rest :)
Thanks again.
I am presuming that serial link with an ip address 1.1.1.254 is a T1 link
so your network is like
t1-->router/seriallink-->router ethlink-->switch ethlink --> vlan
If this is correct can you tell me who provide you 1.1.1.254 address is that from ISP?
Does you ISP do NATing for 192.168.0.0 private addressing or you need to do NATing?
I can help you to setup your network via Teamviewer if thats fine with you.
Switch ethlink does not go to vlan.  It's no switchport with an IP on Gig0/48.  I did try VLANing it and I get the same results.
1.1.1.154 is provided by AT&T as the serial interface to our router.  Default route goes to 1.1.1.253.
There is a route on the router to send all 192.168.16.0 traffic to 2.2.2.206 (GIG0/48).
ISP presumably does not provide NATing.  I don't think there's a NAT issue because from the core switch (192.168.16.1) I can ping to the Internet (when I changed the default route to send all traffic to the T1 vs the primary Comcast connection) and 3.3.3.5 which is set to route through the T1 as it stands today.
This site is remote so I'd prefer not making any major changes that could implicate their Internet access, especially during business hours.
I am hoping that someone sees something that looks out of the ordinary, however, like I mentioned, this site is pretty basic when it comes to the network setup.
First of the thing I dont see any interface assgined on switch withch is going to 3.3.3.5.
If possible could yoou send the output of # sh ip route and ping ouputs from switch and router.
3.3.3.5 is just a route to a web service in another location for me to test traffic across the T1.  The route tells 3.3.3.5 to go to 2.2.2.105 (Router FE 0/0).
Trace Route from the core switch (192.168.16.1) to 3.3.3.5 successfully goes out the T1 router, across the Internet and terminates at 3.3.3.5.
Trace Route from a computer on the LAN (192.168.16.15) to 3.3.3.5 successfully goes to FE 0/0 on T1 router (2.2.2.205) but then dies.
Testing attached.
What happens if you do an extended ping from the core switch and use the vlan 100 SVI IP address as the source IP ?
Jon
Timeout
try to ping following from switch
#ping 3.3.3.5 source 2.2.2.106
#ping 3.3.3.5 source 192.168.16.1
if first one works and second one does not then it mostly the issue with NAT
First one was successful, 2nd one was not per Jon's request.
Where is the issue with the NAT?
192.168.16.0/24 is consider as a private ip address range which is not routable over internet. In order to route that traffic to internet you need to translate private ips' in to public ips' by using NAT.
I think i may have missed something here.
If the traffic is going across the internet via this T1 then yes NAT is probably the issue.
I assumed, maybe wrongly, that this wasn't going across the internet.
Jon
