RADIUS Authentication Error Across the Subnet
faiqmahdi
Hi Guyz
I have configured Microsoft Server 2012 R2 as a RADIUS for Cisco IOS Devices
Server IP Address :  10.95.6.12
Router IP Address Fa 0/0.192                    ---->>>    192.193.194.195
Router IP Address Fa 0/0.6                          --->>>    10.95.6.1
Switch IP Address VLAN 192                     ---->>>    192.193.194.2010.95.6.11
Switch IP Address VLAN 6                          ---->>>    10.95.6.11
When i access the Cisco Devices RADIUS CLIENT with 10.95.6.x Subnet, It works fine
When i access the Cisco Devices through RADIUS CLIENT 192.193.194.x Subnet, It does not pass through the RADIUS Authentication.
Attached in the Picture i can not access the 192.193.194.20 Device but I can access 10.95.6.1 Device.  As soon as I change the IP Address 10.95.6.11 I can access the Device.
Ping is successful across the  Routers / Switches and Server as well.  Below is unsuccessful debug details as well:
Home_Switch#
01:52:30: RADIUS/ENCODE(00000008): ask "Password: "
Home_Switch#
01:52:41: RADIUS/ENCODE(00000008):Orig. component type = EXEC
01:52:41: RADIUS:  AAA Unsupported Attr: interface         [171] 4
01:52:41: RADIUS:   74 74                [ tt]
01:52:41: RADIUS/ENCODE(00000008): dropping service type, "radius-server attribute 6 on-for-login-auth" is off
01:52:41: RADIUS(00000008): Config NAS IP: 0.0.0.0
01:52:41: RADIUS/ENCODE(00000008): acct_session_id: 8
01:52:41: RADIUS(00000008): sending
01:52:41: RADIUS/ENCODE: Best Local IP-Address 10.95.6.11 for Radius-Server 10.95.6.12
01:52:41: RADIUS(00000008): Send Access-Request to 10.95.6.12:1812 id 1645/6, len 85
Home_Switch#
01:52:41: RADIUS:  authenticator 95 FB 3F FE 79 BB AA D6 - C9 26 F4 EC 95 32 80 06
01:52:41: RADIUS:  User-Name           [1]   7   "cisco"
01:52:41: RADIUS:  User-Password       [2]   18  *
01:52:41: RADIUS:  NAS-Port            [5]   6   2
01:52:41: RADIUS:  NAS-Port-Id         [87]  6   "tty2"
01:52:41: RADIUS:  NAS-Port-Type       [61]  6   Virtual                   [5]
01:52:41: RADIUS:  Calling-Station-Id  [31]  16  "192.193.194.50"
01:52:41: RADIUS:  NAS-IP-Address      [4]   6   10.95.6.11
01:52:41: RADIUS(00000008): Started 5 sec timeout
Home_Switch#
01:52:46: RADIUS(00000008): Request timed out
01:52:46: RADIUS: Retransmit to (10.95.6.12:1812,1813) for id 1645/6
01:52:46: RADIUS(00000008): Started 5 sec timeout
Home_Switch#
Any help will really appreciate.
Leo Laohoo
Duplicate posts.
Go here:  http://supportforums.cisco.com/discussion/12154866/radius-authentication-error-across-subnet
