Routing to gateway not working on native
jacobholmjensen
Hi Cisco Community, I'm currently stuck with an issue I hope you can help me with.
I'm trying to practice the whole "management VLAN" idea, and I'm meeting a lot of trouble on the way to understanding...
This is my humble setup with SSH, ICMP-packets and all other stuff working on vlan99 which is my management VLAN. But.. The PC's in VLAN10 can ping the SVI on the switch, but not their gateway 192.168.10.1...
Here is the config for the router:
hostname R1
enable secret 5 $1$mERr$4dpRATIgxQacPVK0CfNV4/
ip cef
no ipv6 cef
username ADMIN password 0 ADMIN
ip ssh version 2
no ip domain-lookup
ip domain-name SSH1
spanning-tree mode pvst
interface GigabitEthernet0/0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0/0.10
description NATIVE
encapsulation dot1Q 10 native
ip address 192.168.10.1 255.255.255.0
interface GigabitEthernet0/0/0.99
description MGMT
encapsulation dot1Q 99
ip address 192.168.99.1 255.255.255.0
interface GigabitEthernet0/0/1
no ip address
duplex auto
speed auto
shutdown
interface GigabitEthernet0/0/2
no ip address
duplex auto
speed auto
shutdown
interface Vlan1
no ip address
shutdown
ip classless
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
login local
transport input ssh
line vty 5 15
login local
transport input ssh
end
And here is the config for the switch:
hostname S1
ip ssh version 2
no ip domain-lookup
ip domain-name SSH2
username ADMIN privilege 1 password 0 ADMIN
interface FastEthernet0/1
switchport access vlan 99
switchport mode access
interface FastEthernet0/2
switchport access vlan 10
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
switchport mode trunk
interface GigabitEthernet0/2
interface Vlan1
no ip address
shutdown
interface Vlan10
description NATIVE
ip address 192.168.10.2 255.255.255.0
interface Vlan99
description MGMT
ip address 192.168.99.2 255.255.255.0
ip default-gateway 192.168.10.1
line con 0
line vty 0 4
login local
transport input ssh
line vty 5 15
login local
transport input ssh
end
The config files are also attached as .txt-files...
Thank you very much for your help
configure the below on interface GigabitEthernet0/1:
switchport trunk native vlan 10
Giuseppe Larosa
Hello @jacobholmjensen ,
as correctly noted by @Georg Pauwen  you have a native VLAN mismatch :
on router side the native VLAN is 10
on switch side it is the default value of 1.
This breaks layer3 connectivty in VLAN 10 as native = untagged  frames are considered by the switch as part of Vlan 1 not VLAN 10.
With the command suggested you can fix the native VLAN mismatch.
Hope to help
Giuseppe
