Routing to vlan with RV325
jackbau765937
Hello everybody
I am trying to setup some routing rules in my RV325 router.
I want to route all data from a subnet to a vlan which I created previously. But in the routing settings I can't choose my vlan in the interface row (see picture).
Am I missing something or can the RV325 not achieve this?
mkazam001
Level 3
Level 3
when you normally add a route, you would either use the next-hop IP or the outbound interface to reach your destination subnet
the following document might be helpful:
https://community.cisco.com/t5/small-business-support-documents/advanced-routing-configuration-on-rv320-and-rv325-vpn-routers/ta-p/3172812
regards, mk
under Port Management --> Vlan Membership, do you have Inter VLAN Routing enabled ?
Yes.
So shouldn't I be able to chosoe vlan17 in 'Advanced Routing' as interface?
