routing- what the command for configure and redistribute a default route for internet access
Moshi
Jaderson Pessoa
locally: ip route 0.0.0.0 0.0.0.0 1.1.1.1
on ospf: default-information-originate always
on eigrp: redistribute static metric 100000 1000 255 1 1500 (set you metric in according your an ambient)
on bgp: default-information originate
guide to bgp: https://learningnetwork.cisco.com/thread/41674
guide to ospf: https://learningnetwork.cisco.com/thread/122701
guide to eigrp: https://learningnetwork.cisco.com/thread/33634
Jaderson Pessoa
*** Rate All Helpful Responses ***
Deepak Kumar
There is no more detail as to which routing protocol are you using?
As @Jaderson Pessoa has mentioned you can use below commands and this will change based on the routing protocol. Also, there are many methods to perform the same.
Static Default Route: ip route 0.0.0.0 0.0.0.0 x.x.x.x --> x.x.x.x is the next hop IP
on ospf:
router ospf 1
on eigrp:
router eigrp 1
on bgp:
Router BGP 10
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Leo Laohoo
Jaderson & Deepak,
It is very clear this thread is school work.
Help the students learn: Post the links to documents and (configuration guides).
Please refrain from handing out answers.
@Leo Laohoo nice Leo, thank for your suggestion.
Jaderson Pessoa
