routing
deepak behera
hallo,
This is my router confihuration...
In my local pc i am ping to router lan,wan.gateway and also dns.....
but problem is my local client cannot access internet in nating configuration..
So any body help me ..
spremkumar
Level 9
Level 9
Hi Deepak
There are few things which needs to be clarified.
what is the ip address being used in your pc and your local client?
which device is used as your local client ?
what is the reason to have 2 sets of ip address blocks under your fastethernet0/1?
Is the isp specific about using 117.240.x.x subnets for your local lan? in that case you can simply assign the next usable ips to both your pc and the local client (subjected that you dont have any other clients out there)
In the second half of the config which you have attached in your post doesnt have any reference to 192.168.0.0/24 under the fastethernet interface.
Also can you use the first config itself and make sure that you have 192.168.0.0/24 alone to start with and also tweak the acls to have only #
access-list 1 permit 192.168.0.0 0.0.0.255
regds
