Routing
Navaz Wattoo
Here is below my diagram
Objective
1.  ping every pc to other pc through static routes
Below Attached the configuration of Routers and also Diagram
Navaz
petenixon
Level 3
Level 3
This should do it:
R1
interface s1/0
ip address 10.1.1.1 255.255.255.252
interface s1/1
ip address 10.1.1.4 255.255.255.252
interface vlan 1
ip route 192.168.2.0 255.255.255.0 10.1.1.2
ip route 192.168.3.0 255.255.255.0 10.1.1.5
R2
interface s1/0
ip address 10.1.1.2 255.255.255.252
interface s1/1
ip address 10.1.1.9 255.255.255.252
interface vlan 1
ip address 192.168.2.1 255.255.255.0
ip route 192.168.1.0 255.255.255.0 10.1.1.1
ip route 192.168.3.0 255.255.255.0 10.1.1.10
R3
interface s1/0
ip address 10.1.1.5 255.255.255.252
interface s1/1
ip address 10.1.1.10 255.255.255.252
interface vlan 1
ip address 192.168.3.1 255.255.255.0
ip route 192.168.1.0 255.255.255.0 10.1.1.4
ip route 192.168.2.0 255.255.255.0 10.1.1.9
You will need to assign your hosts with the correct IP configuration as well as ensure clocking is provided by one router for the serial interfaces (if needed, I don't much use GNS3). Don't forget to no shut the interfaces.
petenixon
Level 3
Level 3
This should do it:
R1
interface s1/0
interface s1/1
interface vlan 1
R2
interface s1/0
interface s1/1
interface vlan 1
R3
interface s1/0
interface s1/1
interface vlan 1
