Routing
Shahideachattil
After completing the configuration site 1 and site 5 should communicate each other but site 7 should not get any route from site 1 and site 5
Hello
Create a GRE tunnel on rtr 2 and rtr 5 using the ospf domain as the transit path , enable eigrp over that tunnel and then advertise the eigrp domain routes.
Example
Rtr 2
int tunnel 25
tunnel source  143.88.83.3
tunnel destination 143.88.83.75
ip address 10.1.25.2 255.255.255.248
router eigrp 17
no auro
network 10.1.25.2 0.0.0.0
network131.42.42.17 0.0.0.0
Rtr 5
int tunnel 52
tunnel source  143.88.83.75
tunnel destination 143.88.83.3
ip address 10.1.25.5 255.255.255.248
router eigrp 17
no auto
network 10.1.25.5 0.0.0.0
network 131.42.42.3 0.0.0.0
Kind Regards
Paul
post the full running configurations (sh run) of all six routers.
Hello
Example
Rtr 2
int tunnel 25
router eigrp 17
no auro
Rtr 5
int tunnel 52
router eigrp 17
no auto
Kind Regards
Paul
Show run >
show ip interface brief>
interface range then no shut all ports
Joseph W. Doherty
Firstly, site 7 already has, by default, site 1 routes on R2 and site 5 routes on R5.  Also by default, R3, R4 and R5 would not have site 1 routes as R2, R3 and R4 would not have site 5 routes.  This default routing topology, may, or may not, meet the requirement that site 7 does not have any site 1 or site 5 routes.
If the default route sharing is acceptable, as @paul driver describes, a tunnel between R2 and R5 could be used to share sites 1 and 5 routes between those sites.
If the default route sharing is not acceptable, you could still use a tunnel as Paul suggests, but you would want to use VRFs on routers 2 and 5 so that each site 7 does not (logically) have any sites 1 and 5 routes.
If this distinction is unclear, with the default route sharing, if somehow, for example, a site 7 packets is delivered to R2 from site 1, it will be routed.  With VRFs, R2 would not forward the packet.
