Routing
Mlex1
Hi everyone it's possible make VPN Tunnel between two router and both Tunnel in state up up and can't ping each other.
If someone has links please share
Thanks in advance,
Wish all the best
I will explain here how you check the tunnel status,
tunnel 0
tunnel IP x.x.x.x
tunnel source y.y.y.y
tunnel destination z.z.z.z
first we check the tunnel with
ping z.z.z.z source y.y.y.y <<- if this ping failed then you need static or dynamic routing for tunnel destination in both ends
second we check the tunnel with
ping x.x.x.2 source x.x.x.1 <<- we check her if there is any FW or ACL deny the tunnel.
ping each other not work probably because you dont use source keyword in your ping
you need to use ping with source keyword, the source here must be the tunnel IP
I done this option  doesn't working
Wish all the best
tunnel 0
tunnel IP x.x.x.x
Привет,
выложи конфигурации обоих маршрутизаторы.
