Not able to ping 8.8.8.8 and internal host no access to web server
hakim17
I have internal network on 192.168.10.0/24 on different VLANs.
Web server on 192.168.10.6
There's ASA firewall between internal host and web server
Problem:
R1 is not able to ping 8.8.8.8
Internal host is not able to ping 192.168.10.6
Shambhu-Kumar
Hello Hakim17,
access list is missing , please add
access-list 1 permit 192.168.10.0 0.0.0.255, this will ping 8.8.8.8 from R1 with source 192.168.10.1
Why there is same IP address in
R1 - GigabitEthernet0/0 172.27.47.25 255.255.255.248
ASA FW - GigabitEthernet0/0 172.27.47.25 255.255.255.248
could you clarify, is R1 GigabitEthernet0/1, connected to ASA FW GigabitEthernet0/1
What is the gateway of Webserver?
where is the routing for 192.168.10.6
in addition to the missing access list mentioned by @Shambhu-Kumar , this does not look right either:
interface GigabitEthernet0/1
description - INTERNAL -
--> ip address 192.168.10.1 255.255.255.252
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
Make sure the mask is correct (probably 255.255.255.0)
nat (inside,outside) source static internal_network internal_network destination static all_network all_network
what is this  NAT !!
internal network no-NAT if the traffic go to 0.0.0.0 ?
I dont get this no-NAT
Hello
You have multiple configuration errors.
Rtr
On the rtr you have acl applied negating traffic that need to be allowed and doesnt have any route for 192.168.10.8/29 residning on the ASA
interface GigabitEthernet0/0
no ip access-group ACL_Outside2Inside in
ip unreachables
ip nat inside source list 1 interface GigabitEthernet0/0 overload
no ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0
no ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0 172.27.47.x
access-list 100 permit ip 192.168.10.8 0.0.0.7 any
ip nat inside source list 100 interface GigabitEthernet0/0 overload
ip route 192.168.10.8 255.255.255.248 GigabitEthernet0/1 192.168.10.2
ASA
Looks like conflicting manual/auto nat statements, and given your topology it seems you may only require section 3 (After-auto) nat to work, plus the static inside route is incorrect.
no nat (inside,outside) source static internal_network internal_network destination static all_network all_network
no route inside 192.168.10.0 255.255.255.0 192.168.10.10
route inside 192.168.10.8 255.255.255.248 192.168.10.10
policy-map global_policy
class inspection_default
inspect icmp
Kind Regards
Paul
