RPS 2300 on Router 2911
dariogustin
I want to know which of the avaliable Power Supply on the RPS 2300 I must choose for the appropriate working of the basic Router 2911 (without PoE functions):
1. 750WAC power supply
2. 1150WAC power supply
Which one of the above PS is the recommended for the 2911?
paolo bevilacqua
750W is more than enough.
Hi team
what the cable used for the router 2911 CAB-RPS2300-E or CAB-RPS2300
This has caught me already so I believe you will need the CAB-RPS2300-E and not the CAB-RPS2300 which I had purchased based on the documentation
The documentation states that:
"Users may order either the CAB-RPS2300-E=   compatible with Cisco Catalyst 3750-E and 3560-E Series Switches or the   CAB-RPS2300= compatible with all other network devices. Extra cables   must be ordered separately or as spares."
So one would assume you would need the CAB-RPS2300, however the 2900s and rps unit have 22 pins and the CAB-RPS2300 has 14 pin on one end and 22 pin on the other. The CAB-RPS2300-E has 22 pins on both ends.
The following thread had users with similar issues if you would like to check it out:
https://supportforums.cisco.com/thread/2077252
