RSP-440-TR DRAM Problem
jm-barreto
I was performing a firmware upgrade to my ASR9006 RSP-440-TR using turboboot. But the process fail due to no enough memory available. The RSP-440-TR it suppose to have 6GB of DRAM but it says that have 4GB. I start to receive multiples error and unable to recover the RSP.
I have perform upgrade before and never have a problem. For the node that i was upgrading i have the same RSP as this one and complete the upgrade without a problem.
This is the output of the total RAM in the bad RSP:
Total DRAM Memory: 4096 MB
This is the output of the total RAM on the good RSP:
Total DRAM Memory: 6144 MB
It is possible that the RAM module on the RSP went bad?
I will appreciate your help interpreting these errors to know what is wrong with the RSP.
CPU reset reason = 2 (CPU_RESET_OIR_POR)
########## Environment Variables ##########
PS1=rommon ! >
?=0
CLUSTER_RACK_ID=0
ACTIVE_FCD=1
IOX_ADMIN_CONFIG_FILE=
BOOT_DEV_SEQ_CONF=
IP_ADDRESS=10.1.4.14
IP_SUBNET_MASK=255.255.255.252
DEFAULT_GATEWAY=10.1.4.13
TFTP_RETRY_COUNT=4
TFTP_TIMEOUT=6000
TFTP_CHECKSUM=1
TFTP_SERVER=10.1.4.13
TFTP_MGMT_INTF=0
TFTP_BLKSIZE=1400
TFTP_FILE=asr9k-mini-px.vm-6.4.2
TURBOBOOT=on,disk0,format
BSI=0
RMEMVA=
CLUSTER_NO_BOOT=
MAC Address from cookie: d4:6d:50:3a:28:80
Board type: 0x00100306
Chassis type: 0x00ef02fb
Slot number: 00
Chassis serial: FOX1742GWT0
System Bootstrap, Version 0.76 [ASR9K x86 ROMMON],
Copyright (c) 1994-2012 by Cisco Systems, Inc.
Compiled on Mon 05/23/2016 20:19:29.12 by myekkar
Rommon : 0.76
Ibex Peak : 6
Jasper Forest: 1.0
Zen-JF : 0.7.92
CBC0 : Part 1=16.116, Part 2=16.117, Act Part=2
Laguna : 0.11.0 (primary)
Dao : 1.10.0 (primary)
UTI : 4.9 (primary)
Timex : 0.2.1 (primary)
Board : 5
mbi_boot_smart_reload() - Fastboot status is zero
Sending Boot Image validation request.
HIT CTRL-C to abort
[CTRL-C]
rommon 1 > c
rommon 1 >
rommon 1 >
rommon 1 >
rommon 1 > ccccccccc
rommon 1 > unset BOOT
unset: "BOOT" does not exist
rommon 2 > unset TFTP_FILE
rommon 3 > sync
rommon 4 > unset BOOT_DEV_SEQ_OPER
unset: "BOOT_DEV_SEQ_OPER" does not exist
rommon 5 > unset MIRROR_ENABLE
unset: "MIRROR_ENABLE" does not exist
rommon 6 > sync
rommon 7 > priv
You now have access to the full set of monitor commands.
Warning: some commands will allow you to destroy your
configuration and/or system images and could render
the machine unbootable.
rommon 8 > diswd
Watchdog Disabled
rommon 9 > IP_ADDRESS=10.1.4.14
rommon 10 > IP_SUBNET_MASK=255.255.255.252
rommon 11 > DEFAULT_GATEWAY=10.1.4.13
rommon 12 > TFTP_RETRY_COUNT=4
rommon 13 > TFTP_TIMEOUT=6000
rommon 14 > TFTP_CHECKSUM=1
rommon 15 > TFTP_SERVER=10.1.4.13
rommon 16 > TFTP_MGMT_INTF=0
rommon 17 > TFTP_BLKSIZE=1400
rommon 18 > TFTP_FILE=asr9k-mini-px.vm-6.4.2
rommon 19 > TURBOBOOT=on,disk0,format
rommon 20 > sync
rommon 21 > boot tftp://10.1.4.13/asr9k-mini-px.vm-6.4.2
Beginning TFTP boot:
TFTP server specified is:
TFTP filename specified is: asr9k-mini-px.vm-6.4.2
MGT LAN 0 port link is down. Verify port connectivity to switch.
Selecting MGMT LAN 1 interface.
IP_ADDRESS: 10.1.4.14
IP_SUBNET_MASK: 255.255.255.252
DEFAULT_GATEWAY: 10.1.4.13
TFTP_SERVER: 10.1.4.13
TFTP_FILE: asr9k-mini-px.vm-6.4.2
TFTP_MACADDR: d4:6d:50:3a:28:80
TFTP_VERBOSE: Progress
TFTP_RETRY_COUNT: 4
TFTP_TIMEOUT: 6000
TFTP_CHECKSUM: Yes
ETHER_PORT: 3
ETHER_SPEED_MODE: Auto Detect
TFTP attempt 1 of 1
GigE link up, waiting for ARP reply ...
Receiving asr9k-mini-px.vm-6.4.2 from 10.1.4.13 !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
File reception completed.
Program load complete, Entry point: 0x1000dc08, size: 0x24c7fee0
Startup-code initializing, running on Storm (00100306)
BSP date: Jun 13 2017 11:47:46
Debugging enabled; debug_flag = 1, vendor_debug_flag = 0
Page Address Extension mode (PAE) enabled with 36bit physical addressing.
Running on a ASR9K x86 RSP
Found 4096MB of main memory
Reading back MTRR config from boot processor.
Found LP at APIC ID 2
Found LP at APIC ID 4
Found LP at APIC ID 6
IPL reports 4 logical processors
Family = 00000006, Model = 0000001e
4 CPU cores available
Initializing logical processor 0 (APIC ID 0).......OK (BSP)
Initializing logical processor 1 (APIC ID 2).......OK
Initializing logical processor 2 (APIC ID 4).......OK
Initializing logical processor 3 (APIC ID 6).......OK
Chassis Type: ASR9006-V2 (00ef02fb)
Region shmwin1: 70000000:b0000000
Region pakman: b0000000:b8000000
System page at phys:00023000 user:fed25000 kern:fed28000
Starting next program at vfe043040
Kernel Dumper Boot Init
Unable to determine IPU base address
*** Welcome to QNX neutrino!
*** ASR9K RSP.
tracelogger: starting tracing in background ring mode
tracelogger running with args: -startring -F 1 -F 2
czip:325:mount=/dev/shmem, image=0, remove=0x1
czip: strings=fed25408, as=fed25a78, num=0x420
czip: 355:start_addr=484007f0, in_size=0x22eca870
Use private TLB mappings
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS XR Software for the Cisco XR ASR9K, Version 6.4.2
Copyright (c) 2018 by Cisco Systems, Inc.
/pkg/lib//install_debug_remote: No such file or directory
Media storage device /harddisk: was repaired. Check fsck log at /harddisk:/chkfs_repair.log
May 11 13:40:20.059: Install Setup: Booting with committed software
May 11 13:40:31.305 : TURBOBOOT: Turboboot process started
May 11 13:40:31.312 : TURBOBOOT: Checking size of device disk0:
May 11 13:40:31.314 : TURBOBOOT: OK
May 11 13:40:31.315 : TURBOBOOT: Waiting for Admin Config to complete
RP/0/RSP0/CPU0:May 11 13:41:05.248 UTC: cfgmgr-rp[164]: %MGBL-CONFIG-3-STARTUP : Configuration Manager could not find any admin configuration to apply from '/disk0:/config/admin/admin.cfg'.
ios con0/RSP0/CPU0 is now available
Press RETURN to get started.
May 11 13:41:08.656 : TURBOBOOT: Admin Config completed
May 11 13:41:08.658 : TURBOBOOT: Formatting disk0:
May 11 13:41:09.806 : TURBOBOOT: Formatting disk0: complete
May 11 13:41:09.807 : TURBOBOOT: Checking Configuration File System (attempt #1).
May 11 13:41:09.834 : TURBOBOOT: Creating any missing directories in ADMIN Configuration File system...
RP/0/RSP0/CPU0:May 11 13:41:13.298 UTC: envmon[210]: %PLATFORM-ENVMON-2-ENV_CONDITION : Outstanding environmental condition exists in the chassis
RP/0/RSP0/CPU0:May 11 13:41:16.472 UTC: wdsysmon[460]: %HA-HA_WD-4-MEMORY_ALARM : Memory threshold crossed: Minor with 328.938MB free
RP/0/RSP0/CPU0:May 11 13:41:16.773 UTC: sysmgr[96]: %OS-SYSMGR-4-MANDATORY_REBOOT_OVERRIDE : mandatory reboot option overridden by request
************ ETH_SERVER Exiting **********
connection down to eth_serverRP/0/RSP0/CPU0:May 11 13:41:21.645 UTC: sysmgr[96]: %OS-SYSMGR-3-ERROR : instdir(1) (jid 255) exited, will be respawned with a delay (slow-restart)
RP/0/RSP0/CPU0:May 11 13:41:21.645 UTC: sysmgr[96]: %OS-SYSMGR-3-ERROR : instdir(255) (fail count 0) will be respawned in 10 seconds
eth_server read failed 'ce' detected the 'warning' condition 'Cannot close connection to eth_server, another thread maintains active connection'eth_server_open failed, retrying cnt: 0RP/0/RSP0/CPU0:May 11 13:41:23.630 UTC: online_diag_svr[456]: %DIAG-DIAG-3-GOLDXR_FAIL : DIAG SVR: error connecting to ethernet server: error code is 1171856384, tried 4 times.
eth_server_open failed, retrying cnt: 1RP/0/RSP0/CPU0:May 11 13:41:24.650 UTC: sysmgr[96]: %OS-SYSMGR-3-ERROR : parser_server(1) (jid 355) exited, will be respawned with a delay (slow-restart)
RP/0/RSP0/CPU0:May 11 13:41:24.650 UTC: sysmgr[96]: %OS-SYSMGR-3-ERROR : parser_server(355) (fail count 0) will be respawned in 10 seconds
eth_server_open failed, retrying cnt: 2RP/0/RSP0/CPU0:May 11 13:41:25.822 UTC: sysmgr[96]: %OS-SYSMGR-3-ERROR : l2fib_mgr(1) (jid 300) exited, will be respawned with a delay (slow-restart)
RP/0/RSP0/CPU0:May 11 13:41:25.822 UTC: sysmgr[96]: %OS-SYSMGR-3-ERROR : l2fib_mgr(300) (fail count 1) will be respawned in 10 seconds
eth_server_open failed, retrying cnt: 3RP/0/RSP0/CPU0:May 11 13:41:26.748 UTC: wdsysmon[460]: %HA-HA_WD-4-MEMORY_STATE_CHANGE : New memory state: Severe
RP/0/RSP0/CPU0:May 11 13:41:26.748 UTC: wdsysmon[460]: %HA-HA_WD-4-TOP_MEMORY_USERS_WARNING : Top 5 consumers of system memory (319528 Kbytes free):
RP/0/RSP0/CPU0:May 11 13:41:26.748 UTC: wdsysmon[460]: %HA-HA_WD-4-TOP_MEMORY_USER_WARNING : 0: Process Name: nvgen_server[348], pid: 209018, Heap usage 11052 Kbytes, Virtual Shared memory usage: 5836 Kbytes.
RP/0/RSP0/CPU0:May 11 13:41:26.748 UTC: wdsysmon[460]: %HA-HA_WD-4-TOP_MEMORY_USER_WARNING : 1: Process Name: statsd_manager_l[419], pid: 741595, Heap usage 9516 Kbytes, Virtual Shared memory usage: 11720 Kbytes.
RP/0/RSP0/CPU0:May 11 13:41:26.748 UTC: wdsysmon[460]: %HA-HA_WD-4-TOP_MEMORY_USER_WARNING : 2: Process Name: ce_switch[54], pid: 106542, Heap usage 9132 Kbytes, Virtual Shared memory usage: 11568 Kbytes.
RP/0/RSP0/CPU0:May 11 13:41:26.748 UTC: wdsysmon[460]: %HA-HA_WD-4-TOP_MEMORY_USER_WARNING : 3: Process Name: fab_xbar[222], pid: 209016, Heap usage 7476 Kbytes, Virtual Shared memory usage: 39936 Kbytes.
RP/0/RSP0/CPU0:May 11 13:41:26.748 UTC: wdsysmon[460]: %HA-HA_WD-4-TOP_MEMORY_USER_WARNING : 4: Process Name: devb-ahci[58], pid: 32793, Heap usage 5592 Kbytes, Virtual Shared memory usage: 436 Kbytes.
eth_server_open failed, retrying cnt: 4RP/0/RSP0/CPU0:May 11 13:41:27.639 UTC: online_diag_svr[456]: %DIAG-DIAG-3-GOLDXR_FAIL : DIAG SVR: error connecting to ethernet server: error code is 1171856384, tried 4 times.
eth_server_open failed, retrying cnt: 5eth_server_open failed, retrying cnt: 6eth_server_open failed, retrying cnt: 7eth_server_open failed, retrying cnt: 8RP/0/RSP0/CPU0:May 11 13:41:31.646 UTC: online_diag_svr[456]: %DIAG-DIAG-3-GOLDXR_FAIL : DIAG SVR: error connecting to ethernet server: error code is 1171856384, tried 4 times.
eth_server_open failed, retrying cnt: 9eth_server_open failed, retrying cnt: 10eth_server_open failed, retrying cnt: 11eth_server_open failed, retrying cnt: 12RP/0/RSP0/CPU0:May 11 13:41:35.653 UTC: online_diag_svr[456]: %DIAG-DIAG-3-GOLDXR_FAIL : DIAG SVR: error connecting to ethernet server: error code is 1171856384, tried 4 times.
RP/0/RSP0/CPU0:May 11 13:41:35.894 UTC: l2fib[300]: %OS-SHMWIN-2-ERROR_ENCOUNTERED : SHMWIN: Error encountered: System memory state is severe, please check the availability of the system memory
May 11 13:41:36.101 : TURBOBOOT: OK
May 11 13:41:36.115 : TURBOBOOT: Initializing ADMIN Configuration Version Manager...
eth_server_open failed, retrying cnt: 13eth_server_open failed, retrying cnt: 14RP/0/RSP0/CPU0:May 11 13:41:37.484 UTC: sysmgr[96]: %OS-SYSMGR-3-ERROR : instdir(1) (jid 255) exited, will be respawned with a delay (slow-restart)
RP/0/RSP0/CPU0:May 11 13:41:37.484 UTC: sysmgr[96]: %OS-SYSMGR-3-ERROR : instdir(255) (fail count 0) will be respawned in 10 seconds
eth_server_open failed, retrying cnt: 15eth_server_open failed, retrying cnt: 16RP/0/RSP0/CPU0:May 11 13:41:39.661 UTC: online_diag_svr[456]: %DIAG-DIAG-3-GOLDXR_FAIL : DIAG SVR: error connecting to ethernet server: error code is 1171856384, tried 4 times.
eth_server_open failed, retrying cnt: 17eth_server_open failed, retrying cnt: 18eth_server_open failed, retrying cnt: 19eth_server_open failed, retrying cnt: 20RP/0/RSP0/CPU0:May 11 13:41:43.668 UTC: online_diag_svr[456]: %DIAG-DIAG-3-GOLDXR_FAIL : DIAG SVR: error connecting to ethernet server: error code is 1171856384, tried 4 times.
eth_server_open failed, retrying cnt: 21eth_server_open failed, retrying cnt: 22eth_server_open failed, retrying cnt: 23eth_server_open failed, retrying cnt: 24RP/0/RSP0/CPU0:May 11 13:41:47.676 UTC: online_diag_svr[456]: %DIAG-DIAG-3-GOLDXR_FAIL : DIAG SVR: error connecting to ethernet server: error code is 1171856384, tried 4 times.
eth_server_open failed, retrying cnt: 25RP/0/RSP0/CPU0:May 11 13:41:48.665 UTC: canb-server[154]: %PLATFORM-CANB_SERVER-3-ALARM_CLEARED : Clear alarm from CBC in slot 0/RSP0/CPU0, alarm code CBC_ALRM_CANBUS_A_FAILED
eth_server_open failed, retrying cnt: 26eth_server_open failed, retrying cnt: 27eth_server_open failed, retrying cnt: 28RP/0/RSP0/CPU0:May 11 13:41:51.683 UTC: online_diag_svr[456]: %DIAG-DIAG-3-GOLDXR_FAIL : DIAG SVR: error connecting to ethernet server: error code is 1171856384, tried 4 times.
eth_server_open failed, retrying cnt: 29eth_server_open failed, retrying cnt: 30eth_server_open failed, retrying cnt: 0eth_server_open failed, retrying cnt: 1RP/0/RSP0/CPU0:May 11 13:41:56.690 UTC: online_diag_svr[456]: %DIAG-DIAG-3-GOLDXR_FAIL : DIAG SVR: error connecting to ethernet server: error code is 1171856384, tried 4 times.
eth_server_open failed, retrying cnt: 2eth_server_open failed, retrying cnt: 3eth_server_open failed, retrying cnt: 4eth_server_open failed, retrying cnt: 5eth_server_open failed, retrying cnt: 6eth_server_open failed, retrying cnt: 7eth_server_open failed, retrying cnt: 8RP/0/RSP0/CPU0:May 11 13:42:03.697 UTC: online_diag_svr[456]: %DIAG-DIAG-3-GOLDXR_FAIL : DIAG SVR: error connecting to ethernet server: error code is 1171856384, tried 4 times.
eth_server_open failed, retrying cnt: 9eth_server_open failed, retrying cnt: 10eth_server_open failed, retrying cnt: 11eth_server_open failed, retrying cnt: 12eth_server_open failed, retrying cnt: 13eth_server_open failed, retrying cnt: 14eth_server_open failed, retrying cnt: 15eth_server_open failed, retrying cnt: 16eth_server_open failed, retrying cnt: 17eth_server_open failed, retrying cnt: 18eth_server_open failed, retrying cnt: 19RP/0/RSP0/CPU0:May 11 13:42:14.704 UTC: online_diag_svr[456]: %DIAG-DIAG-3-GOLDXR_FAIL : DIAG SVR: error connecting to ethernet server: error code is 1171856384, tried 4 times.
eth_server_open failed, retrying cnt: 20eth_server_open failed, retrying cnt: 21eth_server_open failed, retrying cnt: 22eth_server_open failed, retrying cnt: 23eth_server_open failed, retrying cnt: 24eth_server_open failed, retrying cnt: 25eth_server_open failed, retrying cnt: 26eth_server_open failed, retrying cnt: 27eth_server_open failed, retrying cnt: 28eth_server_open failed, retrying cnt: 29eth_server_open failed, retrying cnt: 30eth_server_open failed, retrying cnt: 0eth_server_open failed, retrying cnt: 1eth_server_open failed, retrying cnt: 2eth_server_open failed, retrying cnt: 3eth_server_open failed, retrying cnt: 4eth_server_open failed, retrying cnt: 5RP/0/RSP0/CPU0:May 11 13:42:33.712 UTC: online_diag_svr[456]: %DIAG-DIAG-3-GOLDXR_FAIL : DIAG SVR: error connecting to ethernet server: error code is 1171856384, tried 4 times.
eth_server_open failed, retrying cnt: 6eth_server_open failed, retrying cnt: 7eth_server_open failed, retrying cnt: 8eth_server_open failed, retrying cnt: 9eth_server_open failed, retrying cnt: 10eth_server_open failed, retrying cnt: 11eth_server_open failed, retrying cnt: 12eth_server_open failed, retrying cnt: 13eth_server_open failed, retrying cnt: 14RP/0/RSP0/CPU0:May 11 13:42:43.064 UTC: license_agt[366]: %LICENSE-ASR9K_LICENSE-3-OPERATION_FAIL : ENS write failed, error code Resource temporarily unavailable
eth_server_open failed, retrying cnt: 15eth_server_open failed, retrying cnt: 16eth_server_open failed, retrying cnt: 17eth_server_open failed, retrying cnt: 18eth_server_open failed, retrying cnt: 19eth_server_open failed, retrying cnt: 20eth_server_open failed, retrying cnt: 21eth_server_open failed, retrying cnt: 22eth_server_open failed, retrying cnt: 23eth_server_open failed, retrying cnt: 24eth_server_open failed, retrying cnt: 25eth_server_open failed, retrying cnt: 26eth_server_open failed, retrying cnt: 27eth_server_open failed, retrying cnt: 28eth_server_open failed, retrying cnt: 29
              - You will probably  have to escalate this = contact TAC ,
 M.
marce1000
  - Connect to the ASR with https://cway.cisco.com/cli/  , at the top left press 'System Diagnostics' ,
 M.
Hi @marce1000
I can't use CLI Analyzer because the RSP won't boot the ios. I can't recover the RSP. I try to roll back to the previous ios version that the RSP have but I got the same error. The upgrade fail due to not enough memory available. From what I understood the RSP-440-TR have 6GB of RAM but this RSP shows me that it has only 4GB of RAM.
I tried to analyze the output that I shared manually but since the output is not generated by show-tech or by a show command the CLI Analyzer does not show me anything.
 M.
