RSP 720 booting errors
alireza1368m
I can see many errors when the 7606 with  RSP720-3c booting up.
u can find the booting ups logs in Attached file
below are some of the errors:
whats wrong?!
thanks
rommon 1 > boot
Initializing ATA monitor library...
string is bootdisk:c7600rsp72043-adventerprisek9-mz.122-33.SRC6.bin
Stack pointer       : 0x40000000
monstack            : 0x040088BC
monra               : 0x00000000
edata : 0x300084E0
magic : 0xFEEDFACE
memsize             : 0x40000000
uncomp_size         : 0x07491400
comp_checksum       : 0xCF3E4697
uncomp_checksum     : 0xCF3E4697
CZIP_MEM_BASE       : 0x00000000
_end       : 0x30008500
Self extracting the image...
IOS compressed src copy is     : 0x300084F4
czip + IOS tar size is :0x00A19830
czip + IOS Tar image is now :0x300086F4
cptr is now :0x30008600
IOS compressed dest copy is     : 0x30008600
[OK]
image_entry :0x30000000
__start : 0x30000000
tar_avail_size is now :0x06A77800
Tar image address is             : 0x30A22000
tar_size is           : 0x06A77400
cpu type                   : 0x000000AC
image_info.entry_point   = 0x30000000
image_info.section_count = 0x00000004
image_info.monstack      = 0x040088BC
image_info.monra         = 0x00000000
image_info.param0        = 0x00000002
image_info.param1        = 0x00000000
image_info.param2        = 0x00000000
image_info.param3        = 0x00000000
image_info.reg_k0        = 0x30A22000
image_info.reg_k1        = 0x06A77400
Section Index = 0x00000000
    source    = 0x300086F4
    dest      = 0x30000000
    bytes     = 0x00008000
Section Index = 0x00000001
    source    = 0x300106F4
    dest      = 0x30008000
    bytes     = 0x00000670
Section Index = 0x00000002
    source    = 0x30010D64
    dest      = 0x30008670
    bytes     = 0x00000010
Section Index = 0x00000003
    source    = 0x30010D74
    dest      = 0x30008680
    bytes     = 0x00A110BC
reg_v0: 0x00000000
reg_k0: 0x30A22000
reg_k1: 0x06A77400
tar_start: 0x00000000
tar_size: 0x00000000
tar size is :0x009A163D
Tar magic : ustar Tar filename : C2LC memsize             : 0x40000000
Tar gid         : 035231Tar uncomp_size         : 0x009A163D
Tar mtime         : 11345216526 Tar username          : pallavikTar comp_checksum       : 0x00001425
Tar group name    : buildTar prefix    : tar_size  in czip         : 0x06A77400
monra               : 0x00000000
edata : 0x30008680
magic : 0xFEEDFACE
uncomp_size         : 0x04F5204C
comp_size           : 0x00A110A5
comp_checksum       : 0x248ACE2E
uncomp_checksum     : 0x7CD58FCD
Compressed IOS src copy is     : 0x30008694
tar_dest is :0x39580400
tar_size is :0x06A77400
Compressed IOS dest copy is     : 0x38B6F358
Tar src before IOS decompression is     : 0x30A22000
Tar dest before IOS decompression is     : 0x39580400
compressed IOS  src is     : 0x38B6F358
IOS uncompressed dest copy is     : 0x30030C80
Self decompressing the image : ########################################################################################################################################################################################################################### [OK]
e_shoff :
0x04F51EE4
e_flags : 0x00000000
e_phnum :
0x00000001
Source elf_hdr->e_shnum = 0x00000009
Setting up to copy ELF section 0x00000001
to image_info section 0x00000000
sh_name = 0x0000000B
sh_type = 0x00000001
sh_flags = 0x00000007
sh_addr = 0x08000000
sh_offset = 0x00000060
sh_size = 0x04000000
sh_link = 0x00000000
sh_info = 0x00000000
sh_addralign = 0x00000020
sh_entsize = 0x00000000
Setting up to copy ELF section 0x00000003
to image_info section 0x00000001
sh_name = 0x00000019
sh_flags = 0x00000003
sh_addr = 0x0C000000
sh_offset = 0x04000060
sh_size = 0x00F1827C
sh_addralign = 0x00000008
Setting up to copy ELF section 0x00000004
to image_info section 0x00000002
sh_name = 0x0000001F
sh_addr = 0x0CF1827C
sh_offset = 0x04F182DC
sh_size = 0x00000004
sh_addralign = 0x00000004
sh_type = 0x00000008
sh_addr = 0x0CF18280
sh_offset = 0x04F182E0
sh_size = 0x0000671C
sh_addr = 0x0CF1E99C
sh_size = 0x0203651C
tar file start = 0x0EF5CEB8
cpu type                   : 0x0000002C
image_info.entry_point   = 0x08000000
image_info.reg_k0        = 0x0EF5CEB8
    source    = 0x30030CE0
    dest      = 0x08000000
    bytes     = 0x04000000
    source    = 0x34030CE0
    dest      = 0x0C000000
    bytes     = 0x00F1827C
    source    = 0x34F48F5C
    dest      = 0x0CF1827C
    bytes     = 0x00000004
    source    = 0x39580400
    dest      = 0x0EF5CEB8
    bytes     = 0x06A77400
data_size  in czip         : 0x00008000
bss end of IOS is         : 0x0EF54EB8
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, c7600rsp72043_sp Software (c7600rsp72043_sp-ADVENTERPRISEK9-M), Version 12.2(33)SRC6, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Mon 08-Mar-10 10:49 by prod_rel_team
Image text-base: 0x080000B8, data-base: 0x0C000000
*Jan  1 00:21:34.507: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
*Jan  1 00:21:27.503: CM file (ivfs:/c7600rsp72043_sp-adventerprisek9-m_matrix.cm) is not readable, using internal matrix table
*Jan  1 00:21:34.507: %PFREDUN-6-STANDBY: Initializing as STANDBY processor
*Jan  1 00:22:16.195: %SYS-SP-STDBY-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
*Jan  1 00:21:34.859: %SYS-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ensure console debugging output.
Firmware compiled 14-Jul-09 15:31 by integ Build [100]
*Jan  1 00:22:16.195: %OIR-SP-STDBY-6-CONSOLE: Changing console ownership to route processor
paolo bevilacqua
Already discussed in another thread, please do not post duplicates.
