RSP-7507-IOS- Redundancy
bapatsubodh
We are planning up upgrade IOS on RSP-7507 router. We are having 2 RSP cards in redundant mode. While we were updrading IOS we upgraded it on the first RSP-Card-Flash memory. But when we were upgrading IOS on the second RSP-Card-Flash we found that media is corroupt and copy process was terminating in between. So we have ordered RMA and waiting for the card. Meanwhile we booted the router from the first RSP which was successfully upgraded. But now we dont have redundancy. Now question is when we will install good flash card in second RSP and then upgrade the IOS, and we will configure redundancy. Then I have a problem , and that is do we need to REBOOT the router ? Or redundancy is formed without any reboot of router. As this will take downtime , which is very difficult to get for higher end router.
Please share experience or any document on cisco.com which can tell us that reboot is reqd or not.
Thanx in advance
Subodh
ratheeshrg
Hi can you share which RSP(4, 4+ ,8, 16) you are using and the IOS version in place,both old and new.
ratheeshrg
This action requires no download.
Insert the RSP and upload the new IOS.specify the boot image option
run the following commands
config)# slave reload after reload
config)# slave sync confg
check the redundancy status....it should be in sso mode.
Hope this will help you to do the activity with out any downtime.
