RSP720-3C-GE cannot save the Config
mhashemi1358
We have Cisco7606 with RSP720-3C-GE,when we reset  the router by power off and power on botton the router,first show the message "Warning: NVRAM Area Courrupt,using default value" in boot procedure and then router go to rommon mode and also some times the config erased after physical reboot,Please note we also change the battery of NVRAM on the RSP Board but the problem still exist after physical boot,also we don,t have any problem when when we reset the router by reload command
It,s my pleasure if you help me urgent because we loose all the config whenever we reset the router by power on
For more clarification,following is the boot procedure that I captured when we reset the router with Power on,
System Bootstrap, Version 12.2(33r)SRD5, RELEASE SOFTWARE (fc1)
Copyright (c) 2009 by cisco Systems, Inc.
I2C no ack, please check the DDR SDRAM
I2C bus busy, please check the DDR SDRAM dimm slot 1
Reading monitor variables from NVRAM
Warning: monitor nvram area is corrupt ... using default values
Reset reason 0x0 System Reset by Power On.
Enabling interrupts
Initializing main memory
Initializing ATA controller
Exiting init
C7600-RSP720/RP platform with 1048576 Kbytes of main memory
Download Start
Download Completed! Booting the image.
reg_v0: 0x00000000
reg_k0: 0x04013334
reg_k1: 0x20000000
tar_start: 0x00000000
tar_size: 0x00000000
Tar image address is             : 0x04013334
tar size is :0x00000000
Tar magic :  Tar filename :  memsize             : 0x40000000
Tar gid         : Tar uncomp_size         : 0x00000000
Tar mtime         :  Tar username          : Tar comp_checksum       : 0x00000000
Tar group name    : Tar prefix    : tar_size  in czip         : 0x00000000
Stack pointer       : 0x40000000
monstack            : 0x0400890C
monra               : 0x00000000
edata : 0x20008680
magic : 0xFEEDFACE
uncomp_size         : 0x09268BA0
comp_size           : 0x018EB1FE
comp_checksum       : 0xFB4BC57E
uncomp_checksum     : 0x9E58234B
Compressed IOS src copy is     : 0x20008694
compressed IOS  src is     : 0x3E70C600
IOS uncompressed dest copy is     : 0x20030C80
Self decompressing the image : ######################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################### [OK]
e_shoff :
0x09268A38
e_flags : 0x00000000
e_phnum :
0x00000001
Source elf_hdr->e_shnum = 0x00000009
Setting up to copy ELF section 0x00000001
to image_info section 0x00000000
sh_name = 0x0000000B
sh_type = 0x00000001
sh_flags = 0x00000007
sh_addr = 0x08000000
sh_offset = 0x00000060
sh_size = 0x08000000
sh_link = 0x00000000
sh_info = 0x00000000
sh_addralign = 0x00000020
sh_entsize = 0x00000000
Setting up to copy ELF section 0x00000003
to image_info section 0x00000001
sh_name = 0x00000019
sh_flags = 0x00000003
sh_addr = 0x10000000
sh_offset = 0x08000060
sh_size = 0x011E8CD8
sh_addralign = 0x00000008
Setting up to copy ELF section 0x00000004
to image_info section 0x00000002
sh_name = 0x0000001F
sh_addr = 0x111E8CD8
sh_offset = 0x091E8D38
sh_size = 0x00000168
sh_addralign = 0x00000004
cpu type                   : 0x0000002C
image_info.entry_point   = 0x08000000
image_info.section_count = 0x00000003
image_info.monstack      = 0x0400890C
image_info.monra         = 0x00000000
image_info.param0        = 0x00000002
image_info.param1        = 0x00000000
image_info.param2        = 0x00000000
image_info.param3        = 0x00000000
image_info.reg_k0        = 0x04013334
image_info.reg_k1        = 0x00000000
Section Index = 0x00000000
    source    = 0x20030CE0
    dest      = 0x08000000
    bytes     = 0x08000000
Section Index = 0x00000001
    source    = 0x28030CE0
    dest      = 0x10000000
    bytes     = 0x011E8CD8
Section Index = 0x00000002
    source    = 0x292199B8
    dest      = 0x111E8CD8
    bytes     = 0x00000168
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, c7600rsp72043_rp Software (c7600rsp72043_rp-ADVENTERPRISEK9-M), Version 12.2(33)SRC6, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Mon 08-Mar-10 10:39 by prod_rel_team
Image text-base: 0x08000144, data-base: 0x10000000
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO7606-S (M8500) processor (revision 1.1) with 851968K/65536K bytes of memory.
Processor board ID FOX1623G5WV
BASEBOARD: RSP720
CPU: MPC8548_E, Version: 2.1, (0x80390021)
CORE: E500, Version: 2.2, (0x80210022)
CPU:1200MHz, CCB:400MHz, DDR:200MHz,
L1:    D-cache 32 kB enabled
        I-cache 32 kB enabled
Last reset from power-on
1 Virtual Ethernet interface
48 FastEthernet interfaces
52 Gigabit Ethernet interfaces
3964K bytes of non-volatile configuration memory.
507024K bytes of Internal ATA PCMCIA card (Sector size 512 bytes).
         --- System Configuration Dialog ---
Would you like to enter the initial configuration dialog? [yes/no]:
% Please answer 'yes' or 'no'.
Would you like to enter the initial configuration dialog? [yes/no]: n
Press RETURN to get started!
RMA is the only solution.
5 Replies 5
Edison Ortiz
Faulty Sup module, you need a RMA
Thanks for your reply
Following RMA take long time,is there any other solurion to solve this problem or we don't have another way except RMA??
Thank
M.Hashemi
Thank you for your helping Mr.Engineer
Hi , i have same problem like you did on cisco RSP720-3C-GE(7600 router). When my router start ios then all modules are tested, when is testing supervisior card automatically resets the router and write an error
I saw your problem, is the same, so do you have an idea what is problem.
