RTU license for SSL VPN anyconnect 1941 router
paulwhitecisco
I have an issue with an 1941 router - I am unable to get the SSL VPN working.
I believe the router should be enabled for SSL as its on the Version 15.3(3)M7 IOS. This should have the RTU license feature. Is there a way to enable this for the SSL VPN? I have the correct Security feature on the router.
#show license
Index 1 Feature: ipbasek9
        Period left: Life time
        License Type: Permanent
        License State: Active, In Use
        License Count: Non-Counted
        License Priority: Medium
Index 2 Feature: securityk9
Index 3 Feature: datak9
        Period left: Not Activated
        Period Used: 0  minute  0  second
        License Type: EvalRightToUse
        License State: Not in Use, EULA not accepted
        License Priority: None
Index 4 Feature: NtwkEssSuitek9
Index 5 Feature: ios-ips-update
Index 6 Feature: hseck9
Index 7 Feature: mgmt-plug-and-play
Index 8 Feature: mgmt-lifecycle
Index 9 Feature: mgmt-assurance
Index 10 Feature: mgmt-onplus
Index 11 Feature: mgmt-compliance
6 Replies 6
Mark Malone
Have you ran the command license right-to-use ?
thought you needed a separate license with securityk9 for ssl thought that only covered IPsec vpns on 1900 but could be wrong
Cisco IOS SSL VPN is a licensed feature available on Cisco routers running the Cisco IOS Advanced Security feature set
http://www.cisco.com/c/en/us/products/collateral/security/ios-sslvpn/product_data_sheet0900aecd80405e25.html
If your right I'm not sure what I'm supposed to be telling the router - what WORD?
Router#license right-to-use move ?
  WORD  license name
I've been advised by the license reseller that I don't need to load any licenses onto the router.
do you have a command show license feature , it should show if ssl is enabled
The output of the show license feature command is below -
Feature name Enforcement Evaluation Subscription Enabled RightToUse
ipbasek9 no no no yes no
securityk9 yes yes no yes yes
datak9 yes yes no no yes
NtwkEssSuitek9 yes yes no no yes
ios-ips-update yes yes yes no yes
hseck9 yes no no no no
mgmt-plug-and-play yes no no no no
mgmt-lifecycle yes no no no no
mgmt-assurance yes no no no no
mgmt-onplus yes no no no no
mgmt-compliance yes no no no no
I don't think that covers you don't even see ssl and as well this is what I was saying about needing separate licences for ssl as you do on asa too and 2921 below
https://supportforums.cisco.com/discussion/11659376/ssl-vpn-licensing-cisco-isr-g2-2921
The routers im checking all specifically show ssl under the features
#show license feature
ipbasek9                      no                        no                    no
datak9                        yes                       yes                   no
SSL_VPN                       yes                       yes                   no
Did you have any ;luck getting a definite answer on this , the license team should be able to answer it by an email for you if not
http://cisco.com/go/license
https://tools.cisco.com/SWIFT/LicensingUI/html/contact.html
