Running IOS on 3845 router
johartman
Can I delete the running IOS from flash on an operational 3845 router to make room for the newer version?  The flash isn't large enough to hold two versions.  Doesn't the IOS get loaded and run from NVRAM?  I don't want to take down an operational router but may have no other choice?
paolo bevilacqua
All routers of today run from RAM.
You can safely delete and copy back images while router is running. You can also remove the CF module if you want.
paolo bevilacqua
Thanks!
You're welcome, thanks for nice rating and good luck!
