Running ipsec tunnel mode and transport mode concurrently
Dave Ng
We've a network routing connecting to a MPLS link for our extranet connection to our external business partners. The network traffic are all encrypted using IPSec between us and the external business partners' site, using transport mode.
We have a new partner who would like to establish IPSec connectivity with us over the MPLS network and have two routers (with active and backup) MPLS links.
We would like to configure two IPSec tunnels with the new partner, one primary tunnel to the primary router and one secondary tunnel to the secondary router. To track the availability of the remote peer, we would like to run the IPSec using tunnel mode for the IPSec connection.
May I know if anyone have manage to run both tunnel and transport mode concurrently on the router? If there are better way to design this, please advise as we will like to keep this as simple as possible..
Extract of configuration
crypto isakmp policy 1
encr aes 256
authentication pre-share
group 2
crypto isakmp key partnerA address 1.1.1.1
crypto isakmp key newpartner1 address 198.1.2.6
crypto isakmp key newpartner2 address 198.1.2.10
crypto isakmp nat keepalive 20
crypto ipsec transform-set aes esp-aes 256 esp-sha-hmac
crypto ipsec transform-set VPN_tunnel_mode esp-3des esp-sha-hmac
crypto ipsec profile VTI
set transform-set VPN_tunnel_mode
crypto map vpn local-address Loopback1
crypto map vpn 10 ipsec-isakmp
description partner A
set peer 1.1.1.1
set transform-set aes
match address 110
interface Loopback1
description crypto loopback interface
ip address 10.1.65.1 255.255.255.255
interface GigabitEthernet0/0
description WAN connection to MPLS
ip address 198.1.2.66 255.255.255.252
ip nat outside
ip virtual-reassembly in
duplex full
speed 100
crypto map vpn
interface GigabitEthernet0/1
description LAN connection
ip address 10.1.2.1 255.255.255.0
ip nat inside
duplex full
speed 100
interface Tunnel0
ip unnumbered GigabitEthernet0/0
tunnel source 10.1.65.1
tunnel destination 198.1.2.6
tunnel mode ipsec ipv4
tunnel protection ipsec profile VTI
interface Tunnel1
tunnel destination 198.1.2.10
ip route 0.0.0.0 0.0.0.0 198.1.2.65 name MPLS_PE
ip route 10.0.0.0 255.255.224.0 10.1.2.254 name internal
ip route 198.1.3.0 255.255.255.0 Tunnel 0 track 10 name newpartner_LAN
ip route 198.1.3.0 255.255.255.0 Tunnel 1 track 20 100 name newpartner_LAN
ip sla 10
  icmp-echo 198.1.2.6 source-interface loopback1
  frequency 5
ip sla 20
  icmp-echo 198.1.2.10 source-interface loopback1
  frequency 5
ip sla schedule 10 life forever start-time vow
ip sla schedule 20 life forever start-time vow
david.tran
Level 4
Level 4
there is nothing stopping you from running tunnel mode for one IPSec tunnel and transport mode with another IPSec tunnel from the same router.  Under the "crypto map xxx seq ipsec-isakmp", you just need to specify "mode transport" and that will do it.
Daivd,
Thanks, I think you are referring to specify the "mode transport" in the crypto ipsec transform-set instead of crypto map...
I will try that... any idea if similar change is require on the remote peer.... I really hate the idea of getting our business partner to make any changes since the existing ipsec tunnel running on transport mode is already live..
mode transport
