RV042G VPN
dannimca1
I have three routers connected in this way:
        - router 1 - Linksys RV042 - gateway to Internet
        - router 2 - RV042G  ( WAN connected to router 3, LAN connected to RV042 LAN )
        - router 3 - RV042G ( WAN connected to router 2 )
Router 2 is connected to router 3 by a fiber link ( using mediaconvertors ). Because the path of this fiber is not under control, traffic has to be encrypted. The simplest solution seems to make a VPN between this two. The Internet acces is only possible through router 1. All servers ( DC, DNS etc) are in LAN behind router 1 / router 2.
After VPN was created from LAN behind router 3 I can ping the computers ( by IP and by name ) from router 1/ router 2 LAN by I cannot access Internet ( ping to www.google.com return only the IP and no responses).
I tryed different settings for "advanced routing" but nothing seems to work.
Thank you!
dannimca1
"network diagram"
