RV082 dual wan Terminal Server configuration
smjsoftware
Hello to all,
Thanks in advance for your help.
I've a RV082 with 2 internet connections.
The idea is to permit external connections to my server and if one Internet line falls, automatically switch to the other.
We have configured the router in Smart Link backup
We try to connect with WAN1 and WAN2 enabled and all works fine.
We try to connect with WAN1 disabled and automatically WAN2 is activated.
The problem start here...if WAN1 is activated while there are connections using WAN2, these connections falls!!
How I must configure the router to permit that active connections are not disconnected from WAN2 even when WAN1 connection come back ?
Thanks in advance.
smjsoftware
I forget this information...
Firmware Version : v4.0.4.02-tm (Jul 4 2011 13:30:56)
