I'm struggling to interpret from the manuals whether this is supported on 3.3S:
interface GigabitEthernet0/0/0
ip vrf forwarding VPNA
ip address 10.8.24.2 255.255.254.0
no ip proxy-arp
ip nat inside
interface GigabitEthernet0/0/2
ip address <outside ip> 255.255.255.0
no ip proxy-arp
ip nat outside
ip nat inside source list TEST interface GigabitEthernet0/0/2 vrf VPNA overload
ip access-list extended TEST
permit ip 10.8.24.0 0.0.1.255 any
3.5S releases a feature for intra-VPN NAT called "match-in-vrf"; however, this doesn't support PAT. The configuration guide doesn't mention much of VRF-aware NAT.
Issue I'm having is that ICMP traffic is NAT'd succesfully and logged; however, the router doesn't appear to do anything with UDP or TCP traffic.
Cheers,
Mike
