RV130 ipsec VPN configuration form crippled
bon_durant1
The ipsec VPN server configuration form displays a lot of inactive fields, so I am unable to follow the instructions given in, for example, the documentation here.  I tried setting only the fields I could get to, but the values are not saved.  My configuration view:
  Have I missed a switch that enables the fields?
5 Replies 5
what operating mode is your RV130 in ? You need to be in Gateway mode for the VPN to work (page 39 of the attached guide)...
https://www.cisco.com/c/dam/en/us/td/docs/routers/csbr/rv130w/admin_guide/en/rv130w_admin_en.pdf
This has always been in gateway mode:
Selection_018.pngThanks for the reply.  Any other ideas?
I'm just bumping this with a little more information, namely that the device claims that the firmware, at version 1.0.3.44, is up to date since before I reported the issue.  I did notice the issue much earlier and just didn't have time to troubleshoot it (as if I do now).  It's been far too long without this central feature working.  Does the ipsec VPN server configuration menu appear broken (as in my original post) for any else, or am I alone?
bon_durant1
Another bump, adding that the broken UI (missing edit controls) occurs across multiple client browser/platforms.
bon_durant1
I hope bumps 4 months apart do not annoy too much.  Is there anyone at Cisco concerned that this customer appears to be reporting a defective device to a brick wall?  If you can't reproduce the disabled fields, what else is left?
