RV160 Site to Site VPN 15[IKE] received NO_PROPOSAL_CHOSEN error
markrichard
Test AVPN S2S network ... This should NOT be this hard... straight-up simple VPN setup.
 NO_PROPOSAL_CHOSEN error is like a BS general error bucket non-informative log error... WTH !!!!
The trail and Error troubleshooting is insane - little diagnostic info available
my quest is a Phase I failure, but WHAT! What does NO_PROPOSAL_CHOSEN error suggest ...
Wan Site A 10.22.22.1
Lan Site A 10.1.0.1/24
Wan Site B 10.220.220.1
LAN Site B 10.1.1.1/24
Site A                                      <----->                              Site B
RV160W  Wan  Ping                <----->            RV160 Wan Ping good
10.22.22.1                              <---Ping-->           10.220.220.1
VPNS2S                                  <----->            peer VPN Config Site B
Connect             NO_PROPOSAL_CHOSEN error
Same log error from each site's RV160 logs
10.22.22.1 Wan Interface        <----->            10.220.220.1 Wan
10.1.0.1 Lan Interface        <----->            10.1.1.1 Lan Interface
S2S between both sites peer config inverse of each Wan/Lan
Site A
No. Name Enable Status Phase2 Enc/Auth/Grp Local Group Remote Group Remote Gateway Action
1 ospep Enable DOWN 3des-sha1-modp1024 10.1.0.1/24 10.1.1.1/24 10.220.220.1
Site B
1 ospep Enable DOWN 3des-sha1-modp1024 10.1.1.1/24 10.1.0.1/24 10.22.22.1
Both sites Matching Profiles
IPSec Profile
Keying Mode: Auto
IKE Version  IEKv1
Phase I Options
DH Group: Group2 - 1024 Bit
Encryption: 3DES
Authentication: SHA1
SA LT: 28800
Phase II Options
Protocol Selection: ESP
Encryption: 2DES
SA LT: 3600
Perfect Forward Secrecy: Enabled
Basic Settings
S2S Site A
Enable
Connection Name: ospep
IPSec Profile: Test
Interface Wan
Remote Endpoint Static IP
IP Address: 10.220.220.1
IKE Authentication Method
Pre-shared Key      sfc@testingnetwork12345
Show Pre-shared Key: not enable
Minimum Preshared Key Complexity: not enable
Local Group Setup
Local Identifier Type: Local WAN IP
Local Identifier: 10.22.22.1
Local IP Type: Subnet
IP Address: 10.1.0.1
Subnet Mask: 255.255.255.0
Local Group Setup
Remote Group Setup
Remote Identifier Type
Remote WAN IP
Remote Identifier
10.220.220.1
Remote IP Type
Subnet
IP Address
10.1.1.1
Subnet Mask
255.255.255.0
Aggressive Mode: not enabled
Advanced Settings
Checked: Compress (Support IP Payload Compression Protocol (IPComp))
Checked: NetBIOS Broadcast
Checked: Keep-Alive
Keep-Alive Monitoring Interval 10
Checked: DPD Enabled
Delay Time 10
Detection Timeout 30
DPD Action Restart
No Extended Authentication
No Failover settings
Site B is peer configured as above
Very basic setup ... Site A Log file
Log file debug mode...
2021-Aug-13, 16:52:31 TMT info vpn charon: 05[IKE] received NO_PROPOSAL_CHOSEN error notify
2021-Aug-13, 16:52:31 TMT info vpn charon: 05[ENC] parsed INFORMATIONAL_V1 request 4163274021 [ N(NO_PROP) ]
2021-Aug-13, 16:52:31 TMT info vpn charon: 05[NET] received packet: from 10.220.220.1[500] to 10.22.22.1[500] (40 bytes)
2021-Aug-13, 16:52:31 TMT info vpn charon: 11[NET] sending packet: from 10.22.22.1[500] to 10.220.220.1[500] (196 bytes)
2021-Aug-13, 16:52:31 TMT info vpn charon: 11[ENC] generating ID_PROT request 0 [ SA V V V V V V ]
2021-Aug-13, 16:52:31 TMT info vpn charon: 11[IKE] IKE_SA s2s_ospep[6014] state change: CREATED => CONNECTING
2021-Aug-13, 16:52:31 TMT info vpn charon: Last message '11[IKE] initiating M' repeated 1 times, supressed by syslog-ng on osptest
2021-Aug-13, 16:52:31 TMT info vpn charon: 11[IKE] initiating Main Mode IKE_SA s2s_ospep[6014] to 10.220.220.1
2021-Aug-13, 16:52:31 TMT info vpn charon: 11[IKE] sending draft-ietf-ipsec-nat-t-ike-02n vendor ID
2021-Aug-13, 16:52:31 TMT info vpn charon: 11[IKE] sending NAT-T (RFC 3947) vendor ID
2021-Aug-13, 16:52:31 TMT info vpn charon: 11[IKE] sending FRAGMENTATION vendor ID
2021-Aug-13, 16:52:31 TMT info vpn charon: 11[IKE] sending Cisco Unity vendor ID
2021-Aug-13, 16:52:31 TMT info vpn charon: 11[IKE] sending DPD vendor ID
2021-Aug-13, 16:52:31 TMT info vpn charon: 11[IKE] sending XAuth vendor ID
2021-Aug-13, 16:52:31 TMT info vpn charon: 11[IKE] activating ISAKMP_NATD task
2021-Aug-13, 16:52:31 TMT info vpn charon: 11[IKE] activating ISAKMP_CERT_POST task
2021-Aug-13, 16:52:31 TMT info vpn charon: 11[IKE] activating MAIN_MODE task
2021-Aug-13, 16:52:31 TMT info vpn charon: 11[IKE] activating ISAKMP_CERT_PRE task
2021-Aug-13, 16:52:31 TMT info vpn charon: 11[IKE] activating ISAKMP_VENDOR task
2021-Aug-13, 16:52:31 TMT info vpn charon: 11[IKE] activating new tasks
2021-Aug-13, 16:52:31 TMT info vpn charon: 11[IKE] queueing QUICK_MODE task
2021-Aug-13, 16:52:31 TMT info vpn charon: 11[IKE] queueing ISAKMP_NATD task
2021-Aug-13, 16:52:31 TMT info vpn charon: 11[IKE] queueing ISAKMP_CERT_POST task
2021-Aug-13, 16:52:31 TMT info vpn charon: 11[IKE] queueing MAIN_MODE task
2021-Aug-13, 16:52:31 TMT info vpn charon: 11[IKE] queueing ISAKMP_CERT_PRE task
2021-Aug-13, 16:52:31 TMT info vpn charon: 11[IKE] queueing ISAKMP_VENDOR task
2021-Aug-13, 16:52:31 TMT info vpn charon: 10[CFG] received stroke: initiate 's2s_ospep-1'
2021-Aug-13, 16:52:31 TMT info vpn charon: 12[IKE] IKE_SA s2s_ospep[6013] state change: CONNECTING => DESTROYING
2021-Aug-13, 16:52:31 TMT info vpn charon: 12[IKE] received NO_PROPOSAL_CHOSEN error notify
2021-Aug-13, 16:52:31 TMT info vpn charon: 12[ENC] parsed INFORMATIONAL_V1 request 96138045 [ N(NO_PROP) ]
2021-Aug-13, 16:52:31 TMT info vpn charon: 12[NET] received packet: from 10.220.220.1[500] to 10.22.22.1[500] (40 bytes)
2021-Aug-13, 16:52:31 TMT info vpn charon: 15[NET] sending packet: from 10.22.22.1[500] to 10.220.220.1[500] (196 bytes)
2021-Aug-13, 16:52:31 TMT info vpn charon: 15[ENC] generating ID_PROT request 0 [ SA V V V V V V ]
2021-Aug-13, 16:52:31 TMT info vpn charon: 15[IKE] IKE_SA s2s_ospep[6013] state change: CREATED => CONNECTING
tough one. Have you tried anything higher than DH group 2 (which nowadays is considered a security risk) ?
Thank You for the stronger security tip. but its a VPN connectivity issue 1st and foremost, it makes no difference if a stronger security connection is used, if I cannot even establish a simple lower security VPN connection.
Its a simple Cisco default VPN configured RV160W to a RV160. If we take the Cisco Default configuration settings as the same on each Router besides the different site ipaddresses, it should be plug and play...
what I meant to say was try different DH groups, maybe it works with a higher group...
Also, toggle the 'Perfect Forward Secrecy' (that is, enable and/or disable it on both sides) option. This is a Phase II option. Maybe it works with or without PFS...
pman
Maybe try to change phase 2 options?
I would try to change the following values in Both RV160W and RV160:
Encryption, DH group, Authentication.
(It is important that the values are equal on both RV160W and RV160).
I have attached a link to the guide for making the change through the GUI, maybe this will give ideas to more people.
https://www.cisco.com/c/en/us/support/docs/smb/routers/cisco-rv-series-small-business-routers/Configuring_VPN_Setup_Wizard_on_the_RV160_and_RV260.html
