04-21-2021 01:03 AM - edited 04-21-2021 01:05 AM
I cannot access console port of RV260W switch . no response from router and stuck at black screen
console setting are default 9600 baud rate.
what is the console setting for this router? i cannot see any where in cisco document mentioned about it. so I assume it will be the same for router.
console cable is ok we cross verified with other switch console and its working fine
what could be the reason?
04-21-2021 02:24 AM
Most of the RV devices are managed using Manangement GUI - There is no console access (unlike any other Catalyst switch). as for as i know, this may be for TAC or Future use i guess.
04-21-2021 02:34 AM
somebody needs to confirm console wont work for the mentioned model.
i was able to do SSH before. and took running configuration backup.
client forgot password of the box. i tried to recover password but that didnt accept. client says they didnt change.
now i found that no access to SSH or console or through web. thats the situation
04-21-2021 02:52 AM
I Only see Factory reset is the option here. (to save time) But you can wait others comments if you have concens.
04-24-2021 05:23 AM
Yes we did factory reset.
and we reconfigured.
