RV320 Lastest firmware update
cent4
Hello.
I have error:
"502 Bad Gateway"
I do everything in:
tftp -i 192.168.1.1 put RV32X_v1.2.1.13_20150504-code.bin
But I have error:
"Connect request fail"
Please help me
32 Replies 32
marce1000
 - The -i denotes a binary transfer you have to append the destination address at the end of the command.
 M.
cent4
What is the correct command?
It's still "Connect request fail"
bad
tftp put RV32X_v1.2.1.13_20150504-code.bin -i 192.168.1.1
bad
              tftp -i put RV32X_v1.2.1.13_20150504-code.bin 192.168.1.1
 - i only denotes binary mode for the transfer.
 M.
cent4
Again not good:
 - Try : tftp -i  localhost  put RV32X_v1.2.1.13_20150504-code.bin 192.168.1.1
 M.
cent4
Connect request failed
 - Resort to this document : https://www.paladin.technology/tech/73-cisco-rv325-firmware-update-via-tftp.html , adapt IP address to current of the RV and or make sure your PC is on the same subnet.
 M.
cent4
Connect request failed.
Again
 - The procedure will only work if the RV currently used address 192.168.1.1
 M.
cent4
Yes adress of router is 192.168.1.1
 - Can you ping the RV from the device ( probably your PC ) the upgrade is launched from ?
 M.
cent4
Yes, I can ping 192.168.1.1
not sure if this has been mentioned, but if (and that's what it looks like) you are using a Windows machine, make sure you allow TFTP through the firewall (see link below, scroll down to the section 'Allow TFTP with a Firewall Configuration Change'...
https://www.ittsystems.com/setup-configure-tftp-on-windows-10/#wbounce-modal
cent4
Firewall is disabled.
Again
