RV325 502 Bad Gateway
jerry3
Hi, all,
I have an RV325 (yes, I know it's old) and am having a problem.
When I first got it I did a factory reset and updated the firmware to V1.5.1.13, which worked ok.  I was able to sign on using cisco/cisco and start configuring it.
When I tried to generate a certificate I got the message 502 Bad Gateway.  Any attempt to sign on from then on got the 502 message.
A factory reset via the button did nothing.  I reloaded the firmware - no change.  I hadn't enabled SSH yet (that will be the first thing I do when I get it working) so nothing there.  TFTP still works, but I can't do anything other than upload the firmware again (if there is something else I can do, I'd appreciate suggestions).  I can get into port 8007 but using userid/password cisco/cisco just redisplays the login page.
I've tried Chrome,Firefox and Edge with no luck.  So right now I am completely locked out and have run out of ideas.  Am I SOL with this?
TIA,
Jerry
jerry3
 Ah, SUCCESS, finally!
I ran nmap to find the open ports.  I also found 8008 and 8443 were open.  I had previously tried port 8008 but not 8443.  I used https://192.168.1.1:8443 and was able to get the login page.  The default cisco/cisco worked and I was able to reset the router to factory default including certificate and I'm back in business.
Thanks very much for those who tried to help.  I really appreciate the assistance.  And I hope in the future this will help someone else who has the same problem.
7 Replies 7
Thanks for the response.  Yes, I saw that post and I've tried everything except downgrading to 1.3.2.02 - I don't know where to find that file. Nothing else has worked.
If you can point me to a copy of that version of the firmware I'll try it.
Looks like cisco removed all old firmware, may contact SMB TAC for assistance.
BB
I'll try, but considering how long it has been out of service I am not very hopeful.  Thanks much for trying to help.
jerry3
Another question here.  I can display the login page on port 8007 but the userid/password cisco/cisco does not work.  Is there another default userid/password for this port?
jerry3
Thank you jerry3. I had been stumped by this for several days. Your solution was simple and effective.
