08-31-2021 06:12 AM
Hi to all,
I have a problem with NATs enabled on this router when the Mobile Network connection is active.
The NATs themselves are correctly routed when WAN1 and / or WAN2 is active.
Anyone have any idea how to solve this problem?
I confirm that the Mobile connection works correctly but only outgoing, not incoming.
I tried the Mobile connection in another environment without encountering the same problem.
Can anyone give me some suggestions?
Tnk'so much.
Raffaele
08-31-2021 03:00 PM
Are you looking to Load-balance both the WAN Links?
how is your WAN LB configured ? post the screenshot?
check the config :
09-01-2021 12:03 AM
Hi Balaji,
Thank you for your suggestion.
unfortunately I can't see the link you indicated.
I confirm that the device always has only one active connection (Wan1 / Wan2 / Usb1 / Usb2) never two at the same time.
I am attaching the current MultiWAN configuration screen if I understand what you asked for.
I'm sorry but I'm not a specialist.
Thanks for your patience and for any solution you have
09-01-2021 12:30 AM
Hello
you say wan2 works only egress when nat is enabled but works both ways when nat isn’t enabled correct?
I assume wan1 works okay with nat?
can you provide the running configuration of this router?
09-01-2021 12:48 AM
Hi Paul,
you say wan2 only works on exit when nat is enabled but it works both ways when nat is not enabled correct?
No, I say:
- NATs work correctly when the WAN1 or WAN2 connection is active.
- NATs don't work when I have a USB1 or USB2 connection activated
can you provide the current configuration of this router?
Of course I am attaching the zip file it contains xml of the current configuration, I hope it is useful to understand.
Thanks for your invaluable support
