RV340 Error messages
gjr
Visitor
Logs getting flooded with the following two errors. Any help appreciated
2020-Aug-01, 13:41:13 GMT
warning
network
dnsmasq: ignoring nameserver 127.0.0.1 - local interface
2020-Aug-01, 13:41:11 GMT
error
kern
kernel: [ 1845.205993] ICMPv6: RA: ndisc_router_discovery failed to add default route
Giuseppe Larosa
Hello @gjr ,
the first one is not a true issue 127.0.0.1 cannot be used as a DNS server as it is the local loopback in TCP/IP stack.
The second one looks like more serious:
If you are using IPv6 and IPv6 routing this can have an impact as it tells that the neighbor discovery process of ICMPv6 was not able to add a default route that likely is present in a received router advertisement RA likely from provider router.
If you are not using IPv6 you can ignore the second message too.
Hope to help
Giuseppe
Hi, Thanks for that. I'll ignor the first one for now.
Can you give me any pointers re the second? I am using IPv6 and have only just got it working on the RV340 by turning on 'Router advertisement' which was off by default. I have to sat I'm a bit out of my depth with IPv6 and its implications especially with BT's implementation of it!
