Issue with PIM-SSM Multicast Configuration ISR4431s
I have an issue with my PIM-SSM multicast configuration using ISR4431s.
I am wanting to forward broadcast data from an application from one VLAN in on the multicast source to another VLAN on a multicast router on a small network.  The method I am using is PIM-SSM.  I have a multicast source R1, a multicast transition router R2, and a multicast receiver, the R3 device.
Any insight into why the broadcast data is not forwarding is welcome.
Here is the topology:
              R1---R2---R3
                R1                                                     R2                                              R3
vlan 100 (IP: 10.1.1.1)--10.194.234.226-|--G0/0/0 (IP: 10.194.234.225)---G0/0/0 (IP: 10.156.51.225)-|-G0/0/0 IP: (10.156.51.226)--vlan 600 (IP: 192.142.1.1)
R1 Config (Multicast Source):
hostname R1
ip multicast-routing distributed
ip pim spt-threshold infinity
ip pim ssm default
no ip igmp snooping
vtp mode transparent
vlan internal allocation policy ascending
vlan 100
interface GigabitEthernet0/0/0
ip address 10.194.234.226 255.255.255.252
ip nat outside
ip pim sparse-dense-mode
interface GigabitEthernet0/1/0
switchport access vlan 100
switchport mode access
interface GigabitEthernet0/1/1
interface GigabitEthernet0/1/2
interface GigabitEthernet0/1/3
interface GigabitEthernet0/1/4
interface GigabitEthernet0/1/5
interface GigabitEthernet0/1/6
interface GigabitEthernet0/1/7
interface Vlan100
description /// 10.1.1.1 is the VLAN 100 IP address ///
ip address 10.1.1.1 255.255.255.0
ip nat inside
ip multicast helper-map broadcast 232.1.1.1 bcast-to-mcast ttl 50
ip forward-protocol udp 3205
ip nat inside source static udp 10.1.1.71 3205 10.194.234.226 3205 extendable
ip route 0.0.0.0 0.0.0.0 G0/0/0
ip access-list extended bcast-to-mcast
permit udp any any eq 3205
end
R2 Config (Multicast Transition Router):
hostname R2
vlan 100
ip address 10.194.234.225 255.255.255.252
no shutdown
negotiation auto
interface GigabitEthernet0/0/1
ip address 10.156.51.225 255.255.255.252
no shutdown
negotiation auto
interface Vlan100
description /// 10.10.1.1 is the VLAN 100 IP address ///
ip address 10.10.1.1 255.255.255.0
ip nat inside
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0/0
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0/1
end
R3 Config (Multicast Receiver, NOTE:  192.142.1.99 is not the device that is receiving the data.  Other devices on vlan 600 need the data):
hostname R3
ip pim ssm default
no ip igmp snooping
vlan 600
ip address 10.156.51.226 255.255.255.252
ip multicast helper-map 232.1.1.1 192.142.1.255 bcast-to-mcast
ip igmp version 3
negotiation auto
switchport access vlan 600
interface Vlan600
ip address 192.142.1.1 255.255.255.0
ip broadcast-address 192.142.1.255
ip directed-broadcast
ip igmp join-group 232.1.1.1 source 10.194.234.226
ip igmp version 3
ip nat inside source static tcp 192.142.1.99 61000 10.156.51.226 61000 extendable
end
I checked my post and I uploaded the R2 config incorrectly...  here is the correct one...
hostname R2
no shutdown
negotiation auto
no shutdown
negotiation auto
end
Giuseppe Larosa
Hello @donaldhughes743301172 ,
contrary to what sometimes is written in configuration guide to build a working PIM SSM internetwork you need to configure Ip pim SSm in ALL routers in the path and not only on the edge routers.
I would suggest you to add on R2:
ip pim ssm default
remove also all the commands related to transition to source based tree as there is no RP in PIM SSM the source needs to be known in advance as an IGMPv3 join describes both the group address G and the source address.
Hope to help
Giuseppe
