RV340 - loopback interface
cuqiyuhi
Hi all!
Is it possible to create a loopback interface on RV340 router?
its possible use this for
https://nudecams.name/
https://livecamgirls.name/
https://webcamgirls.name/
This router is set up in a nursing home. They are getting an android App for SOS alert calls from apartments within institution. SOS buttons within apartments are conected to a server which serves the App. This server is also on LAN in the same subnet as wifi clients. App connets to server via WAN external IP address of the router and a forwarded port. SOS system provider orderered a loopback to be created on router in case smart phones loose wifi conectivity and switch to mobile data.
balaji.bandi
No these model do not support loopbak interface config (there may be other way around to fix the issue, so please look admin guide)
BB
Hello
Does this router support NAT?
Possible solution to not having a loopback interface is to DNAT on the physcal interfaces with a virtual ip, this way the vip address is allways avaible no matter what host ip is servicing.
Can you share the current configuration on the rtr please?
Kind Regards
Paul
