S2S VPN Configuration
jimmy10
I want to route traffic through 2 firewalls, via S2SVPN connections, one of the VPNs, R1 to R2 already exists, but the other, R1 to R2 doesn't, so I need to create it.
I am unsure about what IP address/subnet to use for router B? Do I create one that will only be used just for this purpose? or do I use an interface of R2?
I hope the attached diagram makes sense of what I am trying to achieve
5 Replies 5
balaji.bandi
What device is this ? ASA  or Routers
if router what model of the router and IOS Code running here ?
As i understand you looking to flow the traffic between R1 to R2 or R2 to R1 (via R3) - Do you have any other path for R1 to reach to R2 ?
i do not see any issue, as long as you have routing in place and ACL created correctly.
BB
What issue, I think it work
Make another s2s vpn
Acl of this new vpn s2s is permit from spoke2 lan router to spoke1 lan router not from spoke2 lan to hub lan.
In spoke1 you need to be sure that it have route to spoke2 lan pass through hub
In hub you must sure you have route to spoke2 lan.
jimmy10
Sorry forgot to mention, R2 is non Cisco and needs a local subnet in order to connect the VPN.
That is fine, what is the challange you facing here. that solution is feasible with cisco and 3rd party routers(if they support VPN features)
needs a local subnet in order to connect the VPN.  - is this new setup ? you can use any RFC 1918 address, (which is not using in R1 or R3 lan side - not to conflict)
basic need to setup a VPN, Public (if over internet to be reachable) each other agree the VPN settings to form VPN.
BB
R3
crypto isakmp policy 10
hash md5
authentication pre-share
crypto isakmp key mhm address 0.0.0.0 0.0.0.0
crypto ipsec transform-set mhm ah-md5-hmac esp-des
crypto map mhm 10 ipsec-isakmp
set peer 100.0.0.1
set transform-set mhm
match address 110
crypto map mhm1 10 ipsec-isakmp
! Incomplete
crypto map mhm2 10 ipsec-isakmp
set peer 110.0.0.2
match address 100
interface Serial1/0
ip address 100.0.0.3 255.255.255.0
serial restart-delay 0
crypto map mhm
interface Serial1/1
ip address 110.0.0.3 255.255.255.0
crypto map mhm2
ip route 10.0.0.0 255.255.255.0 Serial1/0
ip route 20.0.0.0 255.255.255.0 Serial1/1
access-list 100 permit ip 10.0.0.0 0.0.0.255 20.0.0.0 0.0.0.255
access-list 110 permit ip 20.0.0.0 0.0.0.255 10.0.0.0 0.0.0.255
R1
hash md5
set peer 100.0.0.3
match address 100
interface FastEthernet0/0
ip address 10.0.0.1 255.255.255.0
duplex half
interface Serial1/0
ip address 100.0.0.1 255.255.255.0
crypto map mhm
ip route 0.0.0.0 0.0.0.0 Serial1/0
R2
hash md5
set peer 110.0.0.3
match address 100
ip address 20.0.0.2 255.255.255.0
duplex half
interface Serial1/0
no ip address
shutdown
interface Serial1/1
ip address 110.0.0.2 255.255.255.0
crypto map mhm
ip route 0.0.0.0 0.0.0.0 Serial1/1
access-list 100 permit ip 20.0.0.0 0.0.0.255 10.0.0.0 0.0.0.255
