xconnect with a local gateway from LAN
sebastien3
Level 4
Level 4
I have two 891F routers connected with l2tpv3.
VLAN 1 is connected to a switch via the GE7 port of the router. I can ping any IP on subnet 10.0.0.1/24 in both directions ! Xconnect is UP and ready.
pseudowire-class XCONNECT
 encapsulation l2tpv3
 interworking ethernet
 protocol none
 ip local interface Loopback0
interface Vlan1
 no ip address
 xconnect A.B.C.D 1 encapsulation l2tpv3 manual pw-class XCONNECT
  l2tp id 2 1
 Now I can't create a local gateway for each router... For example on R1 I would like to have the IP 10.0.0.100/24 and on R2 10.0.0.200/24. This allows traffic to go out to the Internet on the local router and not on the remote router !
Bridge IRB or VRF can't work with interface Vlan1.
Have you an solution ?
Thanks !
19 Replies 19
balaji.bandi
how is your network diagram looks like, can you post both the side configuration and what Physical interface connected?
have you tried any other VLAN - other than and VLAN1
BB
interface Vlan1
 no ip address
  l2tp id 2 1
do you try add ip to vlan1 interface in each router ??
sebastien3
Level 4
Level 4
@balaji.bandi:
Here is the diagram. I am in a very simple use ! I also changed the Vlan1 by Vlan100 it does not change the behavior is identical...
@MHM Cisco World:
It's not possible !
R2(config-if)#ip address 10.0.1.200 255.255.255.0
Incompatible with xconnect command on Vl100 - command rejected.
vlan100 contains the xconnect command !
I have one idea but I must check it first.
Can you post show run from R1 and R2 - so we can audit the config and suggest why its not working
also give us information, what router version running on R1 and R2
Looking at the config you provided, you extending the VLAN using connect - that means they are L2 extended each side.
vlan100 contains the xconnect command !  (if this is part of Xconnect you can not create IP here)
if the config is good.
PC 10.0.1.10 should able to ping10.0.1.20
I did some basic testing way back..check below :
https://www.balajibandi.com/?p=1801
BB
Routed Pseudowire - Cisco
Cisco 89x and 888EAISR G2 <<--
according to link I share it must accept ip under svi with xconnect config,
can you check the example in link.
sebastien3
Level 4
Level 4
@balaji.bandi:
Here is the configuration of R2. For R1 it's the same thing, only the IP on GE8/BVI1/Lo0 changes... IOS it's the same on R1/R2.
R2#sh ver
Cisco IOS Software, C800 Software (C800-UNIVERSALK9-M), Version 15.9(3)M5, RELEASE SOFTWARE (fc1)
ROM: System Bootstrap, Version 15.4(1r)T1, RELEASE SOFTWARE (fc1)
System image file is "flash:c800-universalk9-mz.SPA.159-3.M5.bin"
version 15.9
service password-encryption
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 10
no ip source-route
no ip gratuitous-arps
ip vrf xconnect
no ip bootp server
no ip domain lookup
ip cef
ip tcp synwait-time 10
pseudowire-class CL-XCONNECT
 protocol none
bridge irb
interface Loopback0
 ip address X.X.X.X 255.255.255.255
interface BRI0
 no ip address
 encapsulation hdlc
 shutdown
 isdn termination multidrop
interface FastEthernet0
 no ip address
 shutdown
 duplex auto
 speed auto
interface GigabitEthernet0
 no ip address
interface GigabitEthernet1
 no ip address
interface GigabitEthernet2
 no ip address
interface GigabitEthernet3
 no ip address
interface GigabitEthernet4
 no ip address
interface GigabitEthernet5
 no ip address
interface GigabitEthernet6
 no ip address
interface GigabitEthernet7
 switchport access vlan 100
 switchport mode access
 no ip address
interface GigabitEthernet8
 description * WAN *
 ip address Y.Y.Y.2 255.255.255.252
 no ip redirects
 no ip proxy-arp
 ip nat outside
 ip virtual-reassembly in
 ip verify unicast reverse-path
interface Vlan1
shutdown
interface Vlan100
 no ip address
 xconnect A.B.C.D 1 encapsulation l2tpv3 manual pw-class CL-XCONNECT
  l2tp id 2 1
 bridge-group 1
interface Async3
 no ip address
 encapsulation slip
 shutdown
interface BVI1
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 101 interface Loopback0 overload
ip route 0.0.0.0 0.0.0.0 Loopback0
access-list 101 permit ip 10.0.1.0 0.0.0.255 any
control-plane
bridge 1 protocol ieee
bridge 1 route ip
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
end
@MHM Cisco World:
What is your idea ? I have already looked at the document it does not help me more ...
you config encap. L2tpv3 instead as link I share use encap. MPLS.
I don't understand your answer... I don't have a PE to be able to use MPLS?
friend please can you check if the assign IP to interface VLAN with encap mpls is accept?
Encap mpls do not work :
R2#sh run int vlan 100
Building configuration...
Current configuration : 63 bytes
interface Vlan100
end
R2(config)#int vlan100
R2(config-if)#xconnect A.B.C.D 1 encapsulation mpls
Incompatible with ip address command on Vl100 - command rejected.
R2(config-if)#
from your original post:
interface Vlan1
no ip address
l2tp id 2 1
Now you post the below...which one is the one you want us to look at ?
interface Vlan100
no ip address
l2tp id 2 1
bridge-group 1
Yes it's normal @Georg Pauwen ! In the answers above it is asked if I also tried with VLAN1. I copied the conf with my VLAN100 test. Whether with VLAN1 or VLAN100 the behavior remains the same...
before i go in to next level - i would like to ask you simple question - config looks some complicated - you trying to do manythings on the router config.
1. is this real network or you have 2 Router at home you creating Lab ?
2. are you able to reach each other WAN IP address - can you share the ping output.
3. i see you are using NAT here outside - using Loopback0 interface, is that working ?
4. i do not see any inside NAT interface ? or you are not gone that level ?
5. i do see NAT statement ACL 101 , but that not effect since there is no inside interface there.
So what is the goal here in your views and trying to accomplish here.
BB
