09-06-2014 08:19 PM 03-04-2019 11:42 PM 更新
All,
recently faced issue with one of my customer where both CE router used same ASN number , would be great your inputs on the below scenario
Existing router & under production with T1 link
Router A - ASN 655xx working with T1 link - connected to PE X router
Router A - source subnet & loopback address : 10.200.20.0 & 10.200.21.0 connected Giga bit interface Gi 0/1 & Gi 0/2 , 10.1.1.1 , 10.20.1.1 lo0 & lo10 adverting out to the PE
Int Gi 0/1
ip address 10.200.20.1 255.255.255.0
no shut
Int Gi 0/2
ip address 10.200.21.1 255.255.255.0
no shut
int lo0
ip address 10.1.1.1 255.255.255.255 ( management customer )
no shut
int lo 10
ip address 10.20.1.1 255.255.255.255 ( management vendor)
no shut
Router B - ASN 655xx connected with 4T1 link - connected to PE X router
Router B - source subnet & loopback address : 10.200.20.0 & 10.200.21.0 only configured ( not connected to LAN )on the Giga bit interface Gi 0/1 & Gi 0/2 , 10.1.1.1 , 10.20.1.2 lo0 & lo10 .
Int Gi 0/1
no shut
Int Gi 0/2
no shut
int lo0
no shut
int lo 10
ip address 10.20.1.2 255.255.255.255 ( management vendor)
no shut
New router installed same site parallel with four T1 links , plan was to bring up the local LAN interfaces once all 4 T1ckt tested and working condition during this process customer faced connectivity issue.
here the router LAN gi 0/1 & 0/2 configured with same address , the interfaces are not made admin down however cables not connected - so it should not advertise source subnets to cloud
loopback0 have same ip address using on the second router - 10.1.1.1 - it will advertise however impact only accessing this subnet the router ID will be selected by the new router is highest loop back address loopback10 (10.20.1.2) by default
loopback10 have different ip address on the second router - 10.20.1.2 - It will advertise
would be great your inputs what caused the issue - is same ASN number on the CE side reaches to the other CE again blocks everything or PE router creates the loop issue - please suggest
09-06-2014 08:33 PM
What issue exactly you faced? Can you please draw some topology? What i understand that two CE are connected to same PE with T1 link. Same lan ip address assigned on the new CE router's gig interfaces but cables were not connected. Were Gig links in down down state? If they were in up up state and networks will get advertised and it may affect the routing. When issue occurred how did you resolve the issue? Check route for lan subnet on PE and if they recently got refreshed when you disconnected new CE with PE. If that is the case, may be new CE was advertising lan subnets to PE and attracted traffic.
Akash
09-06-2014 09:04 PM
Akash,
issue faced - customer not accessing application , when issue happen new CE router T1 links removed
router A --------------- PE router ----------- router B
same Asn # same Asn #
Also I missed one more parameter here , there are some subnets advertising out to BGP cloud through statically on the old router pointing 10.200.20.2 LAN device interface IP . since the LAN interface IP is active the subnets adverting out
On the new router these static subnets also configured pointing at the IP address 10.200.20.2, however at the new router no cables connected, the Gi 0/1 & Gi 0/2 subnets should not advertise .
thinking on the other subnets which are statically advertised from the old router and received at new router , the ip address 10.200.20.2 also receives on the new router routing table , I have a static below mentioned routes on the new router pointing to 10.200.20.2 which is reachable from the new router .
hence on the new router these source networks ( 10.200.30,31,32/24) installed on the routing table and which intern advertise back to PE and routing loop ?? .
ip route 10.200.30.0 255.255.255.0 10.200.20.2
ip route 10.200.31.0 255.255.255.0 10.200.20.2
ip route 10.200.32.0 255.255.255.0 10.200.20.2
09-06-2014 09:16 PM
Hi ,
router B would not accept prefixes coming from router A due to BGP inbuilt loop prevention mechanism.
http://networktalk.wordpress.com/bgp-tutorial-multihoming-practices-cisco/chapter-a-bgp-general-notions-techniques-and-practices-within-an-isp/a-5-bgp-loop-preventions-mechanisms/a-5-a-ebgp-loop-prevention-mechanism-based-on-as-path-attribute/
So in BGP looping is not possible unless untill you change the default behavior.
My suspect is router B was advertising the lan subnet and attracted traffic. You have to check router b syslogs if Gig interfaces came up during that time or check route age on PE from lan subnet
-Akash
09-07-2014 08:34 AM
the route age is more than 6 weeks , even on router A no logs Gigi flap , customer not moved cable to new router .
09-07-2014 10:32 AM
In that case, I guess next-hop for BGP routes would be loopback 0 (10.1.1.1) which is same configured on router B. If by any chance to reach 10.1.1.1 PE was preferring router B link then it will also cause outage.
エキスパートの回答、ステップバイステップガイド、最新のトピックなどお気に入りのアイデアを見つけたら、あとで参照できるように保存しましょう。
コミュニティは初めてですか?これらのヒントを活用してスタートしましょう。 コミュニティの活用方法 新メンバーガイド
