Help on IP SLA configuration
Hi all,
On the 1841 router (site Lot210) I would like to configure IP SLA for my WAN secondary line which is using ADSL.
Existing primary line is using BGP and connect to the HQ.
Now i want if the BGP interface is down, the secondary ADSL line take over.
Please see below,
1- Configure an IP SLA:
ip sla 1
  icmp-echo 58.139.x.x
  threshold 2000
  timeout 2000
  frequency 5
ip sla schedule 1 start now life forever
2- Create a track object:
track 1 ip sla 1 reachability
Then how about the route? i dont know what to config.
The router default route 0.0.0.0 0.0.0.0 is to the firewall (internet)
10 Replies 10
Tagir Temirgaliyev
I think it is better to configure second BGP neibor throw adsl line
if you can share config I will do detailed instructions
is that possible?
here i attached the existing running-config without the IP SLA
sh run
Building configuration...
Current configuration : 4019 bytes
version 12.4
interface FastEthernet0/0
 description ADSL WAN Interface
 no ip address
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 no ip mroute-cache
 duplex auto
 speed auto
 pppoe enable group global
 pppoe-client dial-pool-number 1
 no cdp enable
interface FastEthernet0/1.3
 description $ETH-LAN$
 encapsulation dot1Q 10 native
 ip address 172.7.100.254 255.255.0.0
interface FastEthernet0/1.4
 description VLAN for Naraya
 encapsulation dot1Q 400
 ip address 172.47.100.254 255.255.0.0
interface Serial0/1/0
 description Primary Line IPVPN
 ip address 58.139.x.x 255.255.255.252
 no fair-queue
interface Dialer1
 ip address negotiated
 encapsulation ppp
 shutdown
 dialer pool 1
 ppp authentication pap callin
 ppp pap sent-username ise@com.my password 7 055A545C7519
router bgp 65322
 no synchronization
 bgp log-neighbor-changes
 network 172.7.0.0
 network 172.17.0.0
 network 172.27.0.0
 network 172.47.0.0
 network 172.57.0.0
 network 172.67.0.0
 neighbor 58.139.x.xy remote-as 23736
 no auto-summary
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 172.27.17.100
probably BGP must be like this
router bgp 65322
 no synchronization
 network 172.7.0.0 mask 255.255.0.0
 network 172.17.0.0  mask 255.255.0.0
 network 172.27.0.0 mask 255.255.0.0
 network 172.47.0.0 mask 255.255.0.0
 network 172.57.0.0 mask 255.255.0.0
 network 172.67.0.0 mask 255.255.0.0
and your advertised networks only 2 now
is this provider AS 23736 ?
you need to ask provider to give you static ip address on adsl link
and BGP neibor address on adsl link
and you will configure second BGP neighbor a.b.x.xy remote-as 23736
after that make
sh bgp nei det
I will do next config
Thanks for the response,
Please see below for the static IP of the Dialer 1, it is 114.133.141.63
LOT_10#sh ip int brie
Interface                          IP-Address         OK? Method Status         Protocol
FastEthernet0/0            unassigned          YES NVRAM  up                up
FastEthernet0/1            unassigned          YES NVRAM  up                up
FastEthernet0/1.1          172.17.100.254  YES NVRAM  up                 up
FastEthernet0/1.2          172.27.100.254  YES NVRAM  up                 up
FastEthernet0/1.3          172.7.100.254    YES NVRAM  up                  up
FastEthernet0/1.4          172.47.100.254  YES NVRAM  up                  up
FastEthernet0/1.5          172.57.100.254  YES NVRAM  up                  up
FastEthernet0/1.6          172.67.100.254  YES NVRAM  up                  up
Serial0/1/0                      58.139.168.170  YES NVRAM  up                  up
Virtual-Access1              unassigned         YES unset  up                    up
Virtual-Access2              unassigned         YES unset  up                    up
Dialer1                           114.133.141.63  YES IPCP   up                    up
only provider knows is it static or dynamic ip address 114.133.141.63
and they can do it static
after that they can use it as bgp neidbor
yes,it is confirm static address.
so does below config OK?
How it should know preference primary and secondary?
router bgp 65322
 no synchronization
 network 172.7.0.0
 network 172.17.0.0
 network 172.27.0.0
 network 172.47.0.0
 network 172.57.0.0
 network 172.67.0.0
 neighbor 58.139.168.169 remote-as 23736
 neighbor 114.133.141.63 remote-as 23736
 no auto-summary
no. it is not.
this is yours address 114.133.141.63
provider should give you corresponding peering BGP neigbor addres
just like
Serial0/1/0                      58.139.168.170  (your side)
neighbor 58.139.168.169 remote-as 23736  (provider side)
preference primary and secondary can be made by weight from your side and provider side
and dont forget to rate posts
How about the routing?
Should I put routing as below,
ip route 0.0.0.0 0.0.0.0 58.139.168.169 210
ip route 0.0.0.0 0.0.0.0 Dialer 1 230
now you have
I think you dont need
and you will get routes to 172.9.0.0/16 throw BGP (serial or adsl)
copy paste here
sh ip route
sh ip bgp
Ok, no need the route
because route will go through BGP
but because the dialer 1 is ip negotiated, is it possible to configure BGP on using interface dialer??
by the way, attached is the log.
