Same VLAN Configuration in two switches - Routing between VLAN
Cisconew
I have attached PT-Topology for VLAN configuration.
Used vlan10,20,30 in SW1 & SW2.End devices connected to SW1 & SW2 is assigned with ip addresses in same subnets in both switches in respect with vlans.
I've created sub interfaces(Fa 0/0.10,0.20&0.30) in Router for Fa 0/0 interface which is connecting to Switch 1.
Should i need to create subinterfaces for Fa 0/1 which is connecting to SW1.
Please find below show run command output for router, SW1 & SW2.
I am little confused here. Please help me.
Router#sh run
Building configuration...
Current configuration : 941 bytes
version 12.4
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Router
ip cef
no ipv6 cef
spanning-tree mode pvst
interface FastEthernet0/0
ip address 192.168.1.100 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/0.10
encapsulation dot1Q 10
ip address 192.168.10.100 255.255.255.0
interface FastEthernet0/0.20
encapsulation dot1Q 20
ip address 192.168.20.100 255.255.255.0
interface FastEthernet0/0.30
encapsulation dot1Q 30
ip address 192.168.30.100 255.255.255.0
interface FastEthernet0/1
ip address 192.168.2.100 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1.10
no ip address
interface Vlan1
no ip address
shutdown
ip classless
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
login
end
SW1#sh run
Current configuration : 1299 bytes
version 12.2
hostname SW1
switchport mode trunk
interface FastEthernet0/2
switchport access vlan 10
switchport mode access
interface FastEthernet0/3
switchport access vlan 20
interface FastEthernet0/4
switchport access vlan 30
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
ip default-gateway 192.168.1.100
line con 0
line vty 0 4
login
line vty 5 15
login
end
SW2#sh run
version 12.2
hostname SW2
interface Vlan1
ip address 192.168.2.1 255.255.255.0
ip default-gateway 192.168.2.100
line con 0
line vty 0 4
login
line vty 5 15
login
end
2 Accepted Solutions
Joseph W. Doherty
Don't know if it's possible in Packet Tracer, but to have a second interface, on the router, connecting to second switch, you would need to "bridge" the interfaces to the switches, and have one bridge interface, per VLAN, on the router.
The other way to deal with your topology, would be to eliminate the router<>SW2 link, and replace with a SW1<>SW2 link, which is trunked. (This approach is more likely to work in Packet Tracer.)
Martin L
Vlans on switch and routers do separate broadcast domains; and router interfaces must be on different networks, subnets.  Hence, On right side of a router, you must use different subnetting scheme (ip addressing). you can use same vlan numbers but usually we use different vlan numbers and networks/subnets/addressing from left side.
if you do have identical vlans and subnets on left and right side of a router, then this would imply 2 different companies connected together.   in such case, you would have to add a router to do NAT translations in order for left side to communicate with right side.
Regards, ML
**Please Rate All Helpful Responses **
6 Replies 6
balaji.bandi
On Router :
no ip address 192.168.1.100 255.255.255.0
no ip address
duplex auto
speed auto
On switch side :
Interface fas 0/1
spanning-tree portfast trunk
test and advise
EDIT :
Sorry i missed the Picture, you can have different VLAN numbers on another side in the router on fas 0/1
BB
this won't work. You cannot have subinterfaces for the same Vlan on two interfaces of the same router. What are you trying to accomplish ?
Joseph W. Doherty
Thanks Joseph,
As you said, i have removed link between SW2 and Router.
Also connected sw1>>SW2 as trunk.
I have changed my Topology as below. It worked for me.
Thanks for your reply
Great!
BTW, what you were trying to do, has advantages and disadvantage to what you have now.
From a L2 perspective, in your original design, if the router fails you lose all L3, but L2 (same VLAN) traffic continues to work normally.
In the second/current design (what I suggested), besides losing all L3 if router fails, if SW1 fails, the remaining SW still loses L3 because it loses path to router. (In such a real world design, you might consider attaching "more important" hosts to SW1 rather than SW2.)
For redundancy, a "better" design, would be to "merge" both topologies, i.e. have the router with a link to both switches and the switches interconnected. That way, if the router failed, your switches would still, at least, maintain the VLANs across both switches, and if either switch fails, the remaining switch would operate normally. (A, somewhat, nice improvement, for only the "cost" of just one additional Ethernet link [assuming router bridged interfaces support multiple interfaces].)
You can further improve redundancy, but only by obtaining better/more hardware.
Martin L
Regards, ML
