Traffic Shaping feature is not supported in user defined class of parent level policy
quycisco123
Dear Cisco Team,
I make qos on VPN Tunnel, but i make command service-policy output name, it show the error below
My cisco router 1921, IOS : c1900-universalk9-mz.SPA.150-1.M5.bin
Hi ,
Try using hierachical policy and see if that helps. Please see below an example.
policy-map SHAPER
class class-default
  shape average 2097152
  service-policy QoS_OUT
policy-map QoS_OUT
class PRIORITY
  priority percent 30
class BT
  police cir 1436000
  conform-action transmit
  exceed-action drop
class class-default
  fair-queue
interface fastethernet 0
service-policy output SHAPER
In most cases, the need to configure hierarchial policy maps arises if you are trying to apply a CBWFQ solution to an ethernet sub
-interface. At that point, you need to nest the policy map with a shaper configured at the parent level. I don't believe you need to use this feature if you are going to apply the child policy to the physical interface unless you need to use the shape
If the above doesnt work and if if still complains then you need you probably have an IP Base Licence and you need to get a DATA licence
