Sample of config for port mirroring
I have a 2960g that I need to mirror one port to 6 other ports, how would I go about configuring that?
2 Accepted Solutions
Hello Jason, Cisco allow one to many with the - or , options. E.g.
Switch(config)# monitor session 1 source interface fastEthernet0/1
Switch(config)# monitor session 1 destination interface fastEthernet0/10 - 11
Which is 10 to 11
Or
Switch(config)# monitor session 1 destination interface fastEthernet0/10, fa0/12
Which is 10 and 12
(Syntax maybe slightly different as I'm just trying to remember from memory, but the comma and hyphen are the options you need)
Hope this helps
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
Or:
Note: You can use monitor session session_number destination command multiple times to configure multiple destination ports.
In that Cisco link I gave in my post
E.g.
Switch(config)# monitor session 1 destination interface fastEthernet0/11
Switch(config)# monitor session 1 destination interface fastEthernet0/12
10 Replies 10
Maybe this helps:
https://supportforums.cisco.com/docs/DOC-2632
Hth
Alessio
Bilal Nawaz
Hello, here's a basic example:
This is saying mirror / SPAN fa0/1 to the destination of fa0/10
http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a008015c612.shtml
Hope this helps
Bilal, thanks but how about 1 to many?
Which is 10 to 11
Or
Which is 10 and 12
Hope this helps
Or:
E.g.
Hello
not posibble to have one tp many
however you can have a whole vlan to a span port
res
paul
Sent from Cisco Technical Support Android App
Kind Regards
Paul
Bilal
isnt the OP refering to 1 to many imterfaces on a single span session - if so this isnt possible.
res
paul
Kind Regards
Paul
Hello Paul, my understanding might not be correct. I thought the OP was asking if one single port can be replicated to many other ports?
So from one interface, mirroring or SPANing to a bunch of ports. Same session.
In which case yes it is possible...
hello
maybe then my interpretation is incorrect
Kind Regards
Paul
You both were very helpful for me to get this done. I thought we weren't going to be able to send monitor destination to more than 2 interfaces. I was able to set it to Gi0/28-31, and Gi0/8-12 as well.
I still believe our enterprise needs a Gigamon implementation for sniffing, IDP, IPS, Web, AV, and other DMZ/internet monitoring things..
I'll see if these will work as-is, and we're still going to push for a dual-datacenter Gigamon w/ centralized monitoring tools.
Thanks!
