Sample VPN Config
bagvanliju
Hai,
I would like to set up a VPN connection ...can some one help me regarding the same ..pls share the sample VPN Config ..i am using cisco 1800 seris router ....
Thanks in Advance
Lijesh.N.C
Here is my current config
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no aaa new-model
ip subnet-zero
ip cef
ip domain name yourdomain.com
ip name-server XXXXXX
no ftp-server write-enable
interface FastEthernet0/0
description WAN CONNECTION
ip address XXXXXX
ip access-group blocknetbios in
ip access-group blocknetbios out
ip accounting output-packets
ip route-cache flow
load-interval 30
duplex auto
speed auto
no mop enabled
interface FastEthernet0/1
description LAN CONNECTION
ip address XXXXXX secondary
ip address XXXXXX
ip route-cache flow
load-interval 30
duplex auto
speed auto
ip classless
ip route 0.0.0.0 0.0.0.0 XXXXXX
ip http server
ip http authentication local
ip http timeout-policy idle 600 life 86400 requests 10000
ip access-list extended blocknetbios
deny tcp any any eq 135
deny tcp any any eq 137
deny tcp any any eq 138
deny tcp any any eq 139
deny tcp any any eq 445
deny udp any any eq 135
deny udp any any eq netbios-ns
deny udp any any eq netbios-dgm
deny udp any any eq netbios-ss
deny udp any any eq 445
permit ip any any
7 Replies 7
Edison Ortiz
Hai Edison,
Thanks for the reply,.Wah its a big file ...i coudint find the appropriate which i am looking for ..my requirement ....is to create a VPN using (ipsec ) ...both end Public ip is given ...only to creat VPN i ve not done this b4 ...and the risk is this has to configured in a prodction router ..
Lijesh.N.C
I suggest reading the link I provided and understand the configuration steps.
Setup a lab and play around with the IPSec configuration
or
Get outside help.
__
Edison.
Hi Edison,
Thanks for the update, will try out the same and let you know the status.
one more doubt right now i am using the IOS
c1841-ipbase-mz.123-8.T7.bin (12.3(8r)T8,)will this support IPSEC VPN ..Which is the recommend one in cisco 1800 (1841) series
-Lijesh NC
Hai,
Can some one suggest me the correct ios which support IPSEC VPN in cisco 1800 series router ....currently (12.3(8r)T8,)
Lijesh.N.C
No, that IOS won't support IPSec VPN.
You need this IOS release c1841-advsecurityk9-mz.123-8.T11.bin
HTH,
__
Edison.
Hai,
Thanks edison,will do the R&D and update the Status ASAP
Lijesh.N.C
