SD WAN and ISR 4k routers
Hi Team
I am very new to the Cisco SD WAN solution, and I have a client who wants to migrate in that direction, but he has some ISR 4321, 4331, 4351 routers....
We want to use basic security features, like "IPS/IDS, URL-Filtering, AMP, SSL Proxy" so, these routers will need to go to 8GB of RAM, correct?
What else would be needed to avoid having any kind of issues in the future? I mean, I'll need to increase the disk and flash memory of these routers as well? Although the documentation only says that RAM would suffice, I really want to be sure. Can someone help me?
balaji.bandi
Sure 8GB good enough, but if you have budget sugested to go for 16GB RAM.
below document very good for reference :
https://www.cisco.com/c/dam/en/us/td/docs/solutions/CVD/SDWAN/sdwan-firewall-compliance-deploy-guide-2020sep.pdf
Also check the End of Live of ISR 4K, Look at new model Cat 8K  (for Longitivity)
https://www.cisco.com/c/en/us/products/collateral/routers/4000-series-integrated-services-routers-isr/select-isr4k-series-platform-eol.html
BB
balaji.bandi
BB
Thank you very much, that was really helpful, i'm reading the documentation and it really cleared some of my doubts...
