11-05-2008 09:19 PM - edited 03-04-2019 12:13 AM
Dear all,
I m newice for using SDM. pls help how to enable it.
I had installed and enable IP http server on router 3600 .
but when I login to router using SDM it opens one file named something ... run APP.shtml.
pls suggest me the solution what to do so that I can use it.
11-05-2008 09:58 PM
have you installed SDM files into the flash card for the routers? you can check by issuing show flash in the router.
11-05-2008 10:11 PM
Dear hasmurizal,
No in Flash: only IOS is there ...which file need to copy there and from where i can get it ?
Dipesh
11-05-2008 11:02 PM
pls help
11-06-2008 01:11 AM
hi patel,
try to access this link to download the SDM files. then place the files into the flash or just check from the link
http://www.cisco.com/en/US/prod/collateral/routers/ps5318/product_data_sheet0900aecd800fd118.html
Browse to the below part and read the "To Download the Software"
(to download you must have cco)
Actually, the SDM software you can install it on your router flash or on your pc. please read the documentation. thanks...
