sdm on router - not able to log in
dvilardo
removed username from new router with sdm - router will now not take any password or username
spremkumar
Level 9
Level 9
You can log onto the router using the console port and access the router.
Once you are in the console prompt you can configure password accordingly.
If you still unable to logon to the router then you can reload the router and follow the password recovery procedure for reseting the password for the router.
regds
