SDWAN and ASA Routing Question/Issue
PJ123
We have to drop a new ASA behind an SDWAN box and I wanted to confirm a route that's giving me a hard time. There are 2 ISP connections to the SDWAN Device which is itself connected to the ASA Outside interface (let's say 6.6.6.6) with the Inside interface (let's say 192.168.1.1) going to the LAN Switch. I need all Internet traffic to flow out of ISP1 Onsite (let's say 1.1.1.1) and Private Traffic over the old MPLS/ISP2 (let's say 2.2.2.2) which is also providing DHCP and such, across the circuit to another site.
Will setting the default outside route to 0 0 1.1.1.1 1 and a route outside 0 0 2.2.2.2 2 in the ASA achieve this? Also, will I need to use PBR as well? I believe I need a Static Route inside from 6.6.6.6 to 192.168.1.0 as well...
If anyone could reply with the specific ASA Config for each necessary command, or an example of this, I would greatly appreciate it!
Thank You,
PJ
rais
Level 7
Level 7
If the SDWAN device is managed, all required policies should be communicated to the vendor. SDWAN will use both ISPs for private traffic and can use any/both of the ISPs for public traffic.
For ASA, there is not much to be done about routing other than defaulting to the SDWAN device.
Thanks.
7 Replies 7
PJ123
UPDATE - Still need a solution for the above scenario
Sdwan connect to ISP or the ASA ?
Can you draw topolgy
MHM
Thanks for the reply, and I do need to do this still so that the Onsite Internet Routes through the ASA (if I have the routing done on the SDWAN Device.....it won't be Firewalled.
So the SDWAN is connected to the onsite ISP so I do need to route inside traffic out to the SDWAN over the outside ASA interface and then out to the local ISP connection from that. Topology is:
SDWAN with ISP1 (onsite) and ISP2  Connected ---> ASA ---> Switch ---> LAN
Hope that is enough for you, appreciate the help!!!
Thanks!
rais
Level 7
Level 7
On SDWAN device, a default out ISP1 and private-space out ISP2 should do it.
On FW, a 0/0 out SDWAN device.
HTH.
Thanks rais!
So, I think I'm overthinking this as I'm used to both ISP's being connected to the ASA (new to SDWAN obviously).
I don't have access to the SDWAN device (but I can verify the default "out" with them). So, as far as the ASA is concerned:
If I have the ASA Outside Interface connected directly to the SDWAN Device (66.x.x.x), and the Onsite ISP that I need as Default connected to the SDWAN Device on 41.x.x.x, will a Default Static Route Out to 41.x.x.x on the ASA do the trick?
Thanks Again, Very Much Appreciated!
rais
Level 7
Level 7
Thanks.
I agree and have said this from the very beginning so thank you very much! I believe I was def given the incorrect information regarding this; there is nothing that I have come up with that makes any real sense to do it any other way...
Thanks Again rais!
