second generation VWIC
any tip how to access / configure second generation of VWIC2-2MFT-T1/E1 on 1841, IOS 12.4.(8b) ?
Previus generation card (VWIC-1MFT-T1/E1) was accessable by:
controller E1 0
framing NO-CRC4
channel-group 0 timeslots 1-6
With new card inserted, I can not issue controller command, it must be some other way to access it.
anrovla
6 Replies 6
spremkumar
Level 9
Level 9
Hi Vladimir
Do make sure you have given card type E1 or T1 command in the global config mode to get controller prompt..
regds
I do have only E1 cards, from both generation. With older one VWIC, from global config I can
do: Controller E1 0 and enter controller config mode. With newer VWIC2 card inserted in the same router, when I try to enter controller E1 0 I get error. Show diag displays that VWIC2 is corectly recognized ...
BR,
Vladimir
BTW, card type E1 work only on 2811 series, but NOT on 1841 (IOS 12.4(8b) ) ...
BR.
Hi Valdimir
Can you post the output of show version and show diag with the error message you get when you type card type e1 ?
regds
