Second WAN link
Steve Coady
Hello
I have a new WAN link, a second WAN link (Site_2), that I want to bring up.
The Primary WAN (Site_1) link has an ASA that dynamically distributes the default gateway using the following config on the ASA inside interface.
interface GigabitEthernet0/0
 nameif Inside
 security-level 100
 ip address 10.0.1.253 255.255.255.240 standby 10.0.1.254
 summary-address eigrp (#) 0.0.0.0 0.0.0.0 200
The Primary ASA connects thru a 3750 switch and then to the CORE devices at Site_1
The Secondary WAN (Site_2) link has the following config on the ASA inside interface. NO dynamic dist of DG
 nameif Inside
 security-level 100
 ip address 10.1.1.253 255.255.255.240 standby 10.1.1.254
The Secondary ASA connects directly to the CORE devices at Site_2.
My Goal is to bring up the connection to the Secondary ASA at the CORE and then test.
I have already verified I can VPN into the Secondary ASA. I now want to move about the Inside network.
What precautions do I need to take to not adversely affect the Production network?
What specific test should I perform from various places across the network to vett out this new WAN link?
sMc
ghostinthenet
Level 7
Level 7
As long as the ASA is distributing the default route via EIGRP, you should be fine as long as you don't override it. For testing throughout the LAN, you can select a specific destination network that is unlikely to be used by the production network and have that specific network advertised via EIGRP from the secondary connection's ASA. Any traffic that is not destined for your test network will still be caught by the primary ASA's default route.
Hello
you dont say how the two cores are conected and how core 2 is receiving routing
I am assuming it dynamically over eigrp from site one over the physical interconnect showing in ypur topology? And given these two sites look like they are already connected how come you cannot access site 2 via site1 over this link?
Also you dont say if core 2 inside interface is to be advertised in eigrp?
lastly you are showing the same physical ip address at each site ( i guess this is a typo?)
Now when you bring core 2 inside interface up at present its Again im assming the only default route as far as i can see from this information is coming over from core 1 so you should be okay.
res
Paul
Kind Regards
Paul
