Secondary IP Block advertised in BGP
lkadlik
Is it possible to advertise a secondary ip block on an interface in BGP?
For ex
int fa0
ip address 10.10.10.1 255.255.255.0 secondary
ip address 172.16.10.1 255.255.255.0
router bgp 18031
network 10.10.10.0
network 172.16.10.0
neighbor 192.168.10.2 remote-as 17525
in this scenario all else being equal ( ie prefix lists, peering is good) would the 10.10.10.0 network be advertised?
Thank you
rtjensen4
Level 4
Level 4
Yes, That will work as you expect. Just fired up the config in GNS3 and it works.
Thank you.
router bgp 18031
network 10.10.10.0
network 172.16.10.0
It won't advertise anything if no auto-summary is configured which is default on latest IOS releases.
You must enter network 10.10.10.0 mask 255.255.255.0 and network 172.16.10.0 mask 255.255.255.0
Regards.
Alain.
Oh yeah. I used the mask statement when I labbed it out.
