Secure eBGP Session with an IPsec VTI?
jjevans1
Hello All,
I am trying to set this up with two Cisco 8000 routers with version 17.09:
www.cisco.com/c/en/us/support/docs/ip/border-gateway-protocol-bgp/118977-config-ebgp-00.html
The problem is that this looks like it is for a different series or older version of IOS.
Does anyone have a updated guide that I can use for reference?
Thank you,
J
You have router or ASA firewall ?
MHM
Just two routers
Then use
Interface tunnel 0
Ip add 5.5.5.1 255.255.255.0
Tunnel source LOCAL-WAN-IP
Tunnel destination REMOTE-WAN-IP
Tunnel protection ipsec profile eBGP
Same in othet router but the tunnel IP will be 5.5.5.2
Router bgp xx
Neighbor 5.5.5.2 remote yy
Neighbor 5.5.5.2 update tunnel 0
Now this for ebgp routing if you want to change the next hop of route learn via ebgp to pass directly via WAN use route-map and set next-hop' this make ipsec tunnel to learn prefix and data pass as clear text via wan interface.
By the way the doc. You share list exactly steps I mention and this doc. Is so so perfect' try it and if you stop in any step send to me.
MHM
