Secure port forwarding
rafalkarpinski
Community Member
My config file:
http://justpaste.it/l3jm
I have nat port forwarding on public ip 2.2.2.4 for private pc 192.168.0.2 on tcp ports 22 and 443
I want to secure this nat with some ACL to limit connections only from 194.24.180.0/23
I've tried with some ACL but it was wrong.
My idea was to create extended ACL like this
ip access-list extended acl_in
 permit tcp 194.24.180.0 0.0.1.255 host 193.108.220.244 eq 443
 permit tcp 194.24.180.0 0.0.1.255 host 193.108.220.244 eq 22
And put it on GE0
 ip access-group acl_in in
But it doesn't work 🙂
Maybe You could help me with that?
Thanks a lot!
6 Replies 6
I can see some differences in PC IP.
whereas in ACL
Did You see my config?
Now I understand that in ACL I have to put private IP. But on which interface I have to put the ACL on?
Which direction, in our out?
Thanks a lot!
personly i can't see your config as its bloked in my domain - http://justpaste.it/l3jm
I made comment based on the description you have given.
Generally ACL will be put on exit interface but it also depend on the network topology. Here no diagram given so can't comment on that.
Config file 🙂
Of course external IP is 2.2.2.4, not 193.108.220.244
My mistake.
! Last configuration change at 11:57:40 UTC Fri Apr 17 2015 by rkarpinski
version 15.2
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone year
service timestamps log datetime msec localtime show-timezone year
service password-encryption
service sequence-numbers
hostname pztest-r1
boot-start-marker
boot-end-marker
aaa new-model
aaa authentication login default local-case
aaa authorization exec default local
aaa session-id common
crypto pki trustpoint TP-self-signed-3662212268
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3662212268
revocation-check none
rsakeypair TP-self-signed-3662212268
crypto pki certificate chain TP-self-signed-3662212268
ip cef
ip dhcp excluded-address 192.168.0.1 192.168.0.20
ip dhcp pool test-lan
network 192.168.0.0 255.255.255.0
domain-name testnet.local
netbios-name-server 192.168.0.2
netbios-node-type p-node
default-router 192.168.0.1
dns-server 8.8.8.8
ip domain retry 3
ip domain name testnet.local
ip name-server 62.233.233.233
ip name-server 192.168.0.2
no ipv6 cef
license udi pid CISCO891-K9 sn FCZ171990KS
redundancy
ip tcp synwait-time 5
ip tcp path-mtu-discovery
ip ssh authentication-retries 2
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface FastEthernet4
no ip address
interface FastEthernet5
no ip address
interface FastEthernet6
no ip address
interface FastEthernet7
no ip address
interface FastEthernet8
description Siec LAN 192.168.0.0/24
ip address 192.168.0.1 255.255.255.0
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0
ip address 2.2.2.2 255.255.255.240
ip nat outside
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
interface Async1
no ip address
encapsulation slip
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip dns view default
domain retry 3
ip nat pool wan1-ip3 2.2.2.3 2.2.2.3 netmask 255.255.255.240
ip nat inside source list nat-lan pool wan1-ip3 overload
ip nat inside source static tcp 192.168.0.2 22 2.2.2.4 22 extendable
ip nat inside source static tcp 192.168.0.2 443 2.2.2.4 443 extendable
ip route 0.0.0.0 0.0.0.0 2.2.2.1
ip access-list standard admin
permit 10.128.0.0 0.0.255.255
permit 194.24.180.0 0.0.1.255
permit 192.168.0.0 0.0.0.255
ip access-list standard nat-lan
access-list 23 permit 10.10.10.0 0.0.0.7
access-list 23 permit 192.168.0.0 0.0.0.255
no cdp run
control-plane
mgcp profile default
alias exec ct configure terminal
line con 0
exec-timeout 30 0
logging synchronous
transport preferred ssh
transport output telnet ssh
line 1
modem InOut
speed 115200
flowcontrol hardware
line aux 0
line vty 0 4
access-class admin in
exec-timeout 30 0
privilege level 15
logging synchronous
transport input telnet ssh
line vty 5 15
exec-timeout 30 0
privilege level 15
logging synchronous
end
Try with:
 permit tcp 194.24.180.0 0.0.1.255 host 192.168.0.2 eq 443
 permit tcp 194.24.180.0 0.0.1.255 host 192.168.0.2 eq 22
And put it on GE0
When I did that I've disabled internet in this company 🙂
Ok, maybe I have to figure it out alone :]
