Select a VRF on a Catalyst 9500 based on IP of VPN pool
Brian Green
I have a scenario where I have anyconnect vpns terminating to a Cisco FTD (configured with FMC).  There are multiple connection profiles, that have separate ip pools, which then enter a catalyst 9500 L3 switch (main router) with multiple vrfs.  I would like one connection profile to route to the global vrf and another connection profile to connect to another vrf.
simplified architecture would look like
VPN client->FTD->catalyst switch -> vrf1/vrf global
Currently the global/default vrf has no issue and works as expected.
I have created a route map pointing to an acl that has the source IP of the ip pool that I wish to route to a specific vrf
route-map SDEV-PBR permit 10
   match ip address SDEV-PBR   !something like permit ip 172.24.67.0 0.0.0.255 any
    set vrf sdev-w2-vrf-test
and then apply it to the interface of the incoming interface vlan
interface Vlan481
ip policy route-map SDEV-PBR
with the route-map applied the vrf vpn cannot pass traffic; if I take away that route map, it works the same as the global vpn.
I receive no hits on my ACL or no packets on my routemap though.  The fact that it changes behavior with the route-map applied makes me think I'm properly identifying the traffic, but may have something mis-configured.
show route-map
route-map SDEV-PBR, permit, sequence 10
Match clauses:
ip address (access-lists): SDEV-PBR
Set clauses:
Policy routing matches: 0 packets, 0 bytes
I don't know if I need to configure something else to select the vrf, or if my hardware is not capable.
Hello
if i understand your request correctly then you will need the following:
GRT:
extended acl with anyconnect users subnet as source/port  destination subnet
route-map calling the extended acl and set ip next-hop towards vrf
static route of the vrf subnet on the switch pointing towards the vrf physical interface
VRF rib
static route of the GRT anyconnect subnet next hop ip of the anyconnect interfac specifying the global route table
Example:
anyconnect subnet = 1.1.1.1/24, interface gig0/0
VRF subnet - 2.2.2.1/24, interface gig0/1
ip access-list extended VRF_ACL
permit ip 1.1.1.0 0.0.0.255 2.2.2.0 0.0.0.255
route-map VRF_rm
match ip address VRF_ACL
set ip next-hop  2.2.2.2
int gig0/0
ip policy route -map VRF_rm
ip route 2.2.2.0 255.255.255.0 gig0/1
ip route vrf VRF 1.1.1.0 255.255.255.0 1.1.1.2 global
Kind Regards
Paul
9 Replies 9
So the link between SW and FTD is in global and you need only anyconnect subnet to be in specific vrf and other not ?
MHM
Yes, this is correct
Dont worry' I will update ypu max tomorrow
Thanks for waiting
MHM
Now
We need to build VRF piece by piece
First you need route-map which you already did
Second you need ip vef recieve <vrf name>
Until this point ping from any IP in vrf to ftd interface IP if sucess then
Third you need (this step I dont so sure) static route with vrf aware in SW toward ftd interface IP
These three steps
MHM
Brian Green
Thank you,
This makes sense.  I tried adding the ip vrf receive to the interface, but it does not appear to be an available command on this vlan interface for some reason.
SW-1(config-if)#ip vrf ?
     autoclassify Enable IP VRF Autoclassify feature
     forwarding Configure forwarding table
     select Enable VRF selection
     sitemap Configure route-map for routes received from this site
I'm not sure if this is a limitation on the 9500-48y4ca hardware or if it is a license issue, or potentially an SDM template (it is set for core).
let me check the keyword you appear to you
MHM
Hello
GRT:
VRF rib
Example:
route-map VRF_rm
int gig0/0
Kind Regards
Paul
Thank you Paul,
  The key to finding my solution was the "global" command at the end of the ip route vrf statement.
Using your example, I had
ip route 2.2.20 255.255.255.0 gig0/1
and
ip route 1.1.1.0 255.255.255.0 1.1.1.2
I removed
and made it just
 and traffic started passing
Hello Brian
Glad to hear you have got it working
The global command in the vrf static is basically telling the vrf rib to route via the Global route table (GRT) for that subnet
Kind Regards
Paul
