06-23-2010 01:47 AM - edited 03-04-2019 08:52 AM
Hello all,
I am trying to implement a solution where the outgoing traffic will go through a low bandwidth secondary link, where as the incomming packets or the reply packets will come through a high bandwidth primary link.
Is this can be done? Or do i need a 3rd party devices to do this? The reason I am trying to acheive this solution is, both the WAN links are expnisve Sattelite links.
Any thoughts?
Nimal
06-23-2010 02:00 AM
Yes, it can be done. I recommend you engage a reputable consultant or certified cisco partner for the configuration details.
06-23-2010 02:25 AM
Is that is so difficult?
Our company doesnt have any support packages from Cisco / Partner. So i have to figure it out by myself?
Are there any links or basic guidlines to do that?
Cheers
06-23-2010 02:45 AM
Hi Nimal,
Policy Based routing (PBR) may help you engineer your outbound traffic.
http://www.cisco.com/en/US/products/ps6599/products_white_paper09186a00800a4409.shtml
Kevin
